type r mani of b16a2-IDLES WAY HIGH! help...
Old Aug 17, 2005 | 01:20 PM
efjuice's Avatar
Default type r mani of b16a2-IDLES WAY HIGH! help...
Everything is installed...all lines ran properly...do I need to change to an integra IACV? Using b16a throttle body.....and there is one coolant line left from the mani but blocked off now. Idles at 2500 and blows white smoke(which is probably cleaner left in the mani)..Any help or vaccum/coolant diagrams to double check wouldnt hurt. ALREADY SEARCHED!..thanks
Old Aug 17, 2005 | 02:11 PM
efjuice's Avatar
up
Old Aug 17, 2005 | 02:30 PM
A.E Motoring's Avatar
Default Re: type r mani of b16a2-IDLES WAY HIGH! help... (efjuice)
try adjusting the idle screw?
Old Aug 17, 2005 | 02:33 PM
SirRevvs's Avatar
Default Re: type r mani of b16a2-IDLES WAY HIGH! help... (SPNFEDEJ)
Dumping white smoke out your exhaust? Idling crazy? Coolant lines not hooked up? I dunno if its possible but are you somehow dumping coolant into your intake beacuse of the hose you didn't hook up? I don't take apart alot of manifolds so this is just a way out there assumtion.
Old Aug 17, 2005 | 03:50 PM
efjuice's Avatar
The R mani has an extra coolant line that is supposed to be blocked......anyone have any coolant line routes for a type R
Old Aug 17, 2005 | 08:11 PM
efjuice's Avatar
Default Re: (efjuice)
SOLVED-small gasket leak from the coolant port to the runners
Old Aug 17, 2005 | 09:37 PM
BLUE EH3's Avatar
Help we my pennies
where is it at?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">try adjusting the idle screw?</TD></TR></TABLE>
Old Aug 17, 2005 | 09:58 PM
FalkenSiR's Avatar
Default Re: type r mani of b16a2-IDLES WAY HIGH! help... (BLUE EH3)
So does it still idle high?
Old Aug 18, 2005 | 01:25 AM
BoOstedEM1's Avatar
So is everything solved or just the white smoke...
GooseS2000
Mar 21, 2013 08:25 AM
lude98SH
Aug 12, 2007 07:49 PM
JDM00SI
Jan 8, 2007 09:06 AM
vtakvtrak
May 22, 2006 02:15 PM
I Want An Si
Jan 15, 2005 04:28 PM
