What size wheel spacer for drag rims...
Old Aug 17, 2005 | 12:32 PM
Daily Interlude's Avatar
Default What size wheel spacer for drag rims...
What's the typical size wheel spacer needed to run drag rims? I have a set and know they'll need spacers. Is there an easy way to determine the width? Will 5mm spacers do it or will I have to get extended lugs too (I hear anything over 5mm will require the extended lugs)?
Old Aug 17, 2005 | 01:07 PM
flip1199's Avatar
Default Re: What size wheel spacer for drag rims... (Daily Interlude)
your gonna need extended studs and open ended lugnuts if u run spacers to comply with the rules.
Old Aug 18, 2005 | 05:33 AM
1fastVX's Avatar
Default Re: What size wheel spacer for drag rims... (flip1199)
It would help if you told us what type of rims you are running.
John
Old Aug 18, 2005 | 12:01 PM
I don't know. There's no markings on the rims itself. I checked.
I'll have to take pics of them and maybe someone can recognize them...
6speed-ferio
Feb 26, 2009 05:57 PM
hyabusa hunter
Dec 30, 2007 08:56 PM
cnydc2
Jan 19, 2005 03:03 PM
7rrivera7
Oct 22, 2002 02:25 AM
