Dpr cams on 11:5 compression Ls Vtec
Old Aug 17, 2005 | 10:57 AM
RgvLsvtec's Avatar
Default Dpr cams on 11:5 compression Ls Vtec
I want to adjust the cam gears but i dont want to risk bending valves or messing up the pistons if i mess up. I was wondering if anyone has dpr cams and what they have the cam gears set at? I have 11:5 compression. thanks for any info.
DPR FI Touring Camshafts
DPR FI Touring Camshafts are a result of years of racing touring cars, drag cars, rally, and formula cars. The profiles are proprietary and are specific to the nature of the required application of a given sport compact engine design. They are designed to provide optimal peak power, fuel efficiency for the given application, and the most usable torque throughout the entire RPM band. Cores are cryogenically treated, then machined to finished specs, then treated again to strengthen the surface metal, and properly orient the metal grain to fight metal fatigue and wear. B-Series VTEC Fitment Only! Requires Valve Train Kit and High compression pistons for maximum performance. Click Here forTouring Cam Specifications.
Advertised Duration Duration @ .050 Lift
IN 284 ---------------248-------------------- 12mm
EX 284 --------------- 248 ------------------ 12mm
Modified by RgvLsvtec at 12:15 PM 8/17/2005
Old Aug 17, 2005 | 12:36 PM
EG_H2B's Avatar
Default Re: Dpr cams on 11:5 compression Ls Vtec (RgvLsvtec)
call DPR. dan is a great guy. he will help you out
lude98SH
May 17, 2008 06:17 PM
bluedlude
Nov 29, 2006 10:12 AM
d16dcoe45
Feb 4, 2006 09:05 AM
Superdragr45
Oct 25, 2004 10:47 PM
