check engine light flashes when i hit a bump
ive got a b18b in my 97 coupe.
ill be driving normally, and when i hit a bump, the car boggs, the check engine light flashes, and my tach and speedo jump.
even when i coast (not on the gas) over a bump, the same **** happens
the check engine light doesnt stay on, it just flashes real quick, then shuts off.
it seems like my car drives normally, untill im on a bumpy road.
any one have an idea?
You have a lose connection on the ground terminal for the ecu and its located by the thermostat housing by the water temp sensor.
Let me know what happens ?
Modified by CRXVTEC305 at 10:06 AM 8/17/2005
"see what the code in the ecu is for and then just find that sensor and follow the wires back to the ecu...done"
i would, but the check engine light doesnt stay on. it just flashes once, then its gone.
Good advise from CRXVTEC305 - Its easy to overlook. Follow the radiator hose up to the thermostat cover. One mounting bolt on the T-Stat cover is a ground point. It could be dirty and or loose.
CRXVTEC305 - THE BOLT WAS LOOSE
it was really loose actually. i took it out for a spin, everything felt normal.
BUT when i took it past 5k rpms through a couple of gears, the check engine light came on....
ill have to go see what that is.
thanks for the help though,
it was really loose actually. i took it out for a spin, everything felt normal. BUT when i took it past 5k rpms through a couple of gears, the check engine light came on....
it almost sounds like something with the ignitor in the distributer. tach bouncing, ect, i bet one of the spade connectors on that is loose, put the dizzy car off, then rotor button and plastic shield thingy and u will see about 4 spade connectors attached to the ignitor, make sure those are all tight and the screws they attach to as well
usdmEHboy
Feb 18, 2007 07:34 AM
mtownsi
Feb 22, 2006 07:32 AM
Hexicus
Jan 27, 2003 03:43 PM
