Brake Parts List
Old Aug 16, 2005 | 08:29 PM
Tyson's Avatar
Default Brake Parts List
id like to make a list of the brake parts and prop valve numbers on cars that come stock that are relevent to 88-91 civic and crx. meaning, parts must fit our chassis and are interchangeable, so i dont care about a 2000 civic ABS prop valve.
if you have anything to contribute, please post it. I will continue to update the list as I gather information. ill include official part numbers wherever applicable. feel free to cross reference and check if the information is correct.
here is a more graphical spreadsheet.
http://www.norcalcrx.org/tyson/brakepartslist.xls
i am using these references, as well as visual checks.
http://www.slhondaparts.com/
http://www.porterfield-brakes.com/
http://www.napaonline.com/
Modified by Tyson at 3:19 AM 8/18/2005
Old Aug 18, 2005 | 02:20 AM
Tyson's Avatar
Default Re: Brake Parts List (Tyson)
interesting. the integra brake booster is double diaphram and the other 15/16" master cylinders have 9" boosters, as opposed to 8".
Old Aug 18, 2005 | 04:15 AM
g2tegsown's Avatar
I like this idea since I soon will have to do this on my rex
Old Aug 18, 2005 | 12:53 PM
Tyson's Avatar
what other cars and parts are compatible with the ef?
Old Aug 18, 2005 | 01:08 PM
dr_latino999's Avatar
Well there is that nifty OEM Brake conversion that Jonathan_ED3 came up with for us not using the EX/DA Hubs, you should be able to mooch a whole bunch of parts from that list.
Old Aug 18, 2005 | 01:51 PM
Tyson's Avatar
Default Re: Brake Parts List (dr_latino999)
bah, that thread gave me nothing but headaches. i dont consider it an oem switch if you gotta machine a part.
are EG prop valves interchangeable with EF?
Old Aug 18, 2005 | 01:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">bah, that thread gave me nothing but headaches. i dont consider it an oem switch if you gotta machine a part.
are EG prop valves interchangeable with EF?</TD></TR></TABLE> I don't think so, but I need to picture to referencel. I know EK aren't. Oh, and eventually in that thread they found a bracket that didn't require the machining.
Old Aug 18, 2005 | 02:02 PM
Tyson's Avatar
i cant open up that thread without it crashing ie for some reason anyway.
more headaches...
i think EG's can use EF compatible master cylinders tho... theres a thread that talks about using the 15/16 EX MC
Old Aug 18, 2005 | 02:10 PM
The master cylinders are interchangeable, do you have listed down the Accord LX-I and older Prelude MCs as interchangeable as well?
Old Aug 18, 2005 | 02:12 PM
Tyson's Avatar
ill probably add some foot notes. but i dont want it to become too verbose either.
so if i just limit it to things that FIT, then it should be pretty self explanatory.
what i find interesting is that the S and Si preludes have DIFFERENT MC! so which is which... i need to confirm which one ppl are talking about are 15/16", or are both, and if so, whats the difference. because the part numbers are different.
which is why id like others to help confirm things, but seems like no one cares.....
ppl just want to be spoon fed and told what to do i guess...
Old Aug 18, 2005 | 03:01 PM
Well I do have the Accord LX-i MC, I just had to bend one line about 45 degrees to bolt on flush.
Old Aug 18, 2005 | 03:11 PM
Tyson's Avatar
yeah, so whats the deal with the prelude S then. is that usable? does that have the same bending requirement... what size is that? whats the prop valve number?
the reason im so curious is because the S model has the same calipers as the 90-91 CRX Si. but oddly has a different rear piston part number, although the rotor is the same.... just trying to piece the puzzle...
Old Aug 18, 2005 | 03:29 PM
From a thread of mine back in the day - https://honda-tech.com/zerothread?id=1112638
3030 - 1990 LX Sedan Manual
Old Aug 18, 2005 | 03:34 PM
Tyson's Avatar
thanks. ill research the whole car later tonite.
Old Aug 21, 2005 | 11:14 PM
Tyson's Avatar
anyone happen to know why the 2nd gen HF drums and backplate are different?
(i know about the 1st gens being aluminum and finned, but the 2nd gens are certainly not that obviously different...)
Old Aug 23, 2005 | 04:31 AM
DpSyChO's Avatar
I dunno if its what you are wanting, but, I got 2 sets of 17cl15vn calipers from the junkyard not long back. One was of a 92 vigor , the other was off a 92 legend. As far as I know, thats the only parts that can be moded to work on a 4g civic. If you want to add it to your list, I'll look to see what trim they were the next time I go there. Oh, and one more thing, are you not going to worry about rear caliper on your list?
Old Aug 23, 2005 | 05:02 AM
crx34's Avatar
Here is a write I found on here awhile ago.... https://honda-tech.com/zerothread?id=1171175
Old Aug 23, 2005 | 05:58 AM
CRX T-Si's Avatar
Default Re: (crx34)
Thats what I got....Accord wagon calipers shaved 1/8" off the mounting bracket and walla......11" brakes.
em2Dima
Honda Civic (2001 - 2005)
Jan 27, 2012 11:48 AM
EJ2_B16
Jan 14, 2006 01:30 PM
kyle h.
Feb 3, 2003 09:59 AM
pmachan
Nov 2, 2001 11:49 AM
