Rubbing Grinding Noise From Front
Old Aug 16, 2005 | 08:21 PM
BlueIntegraBoy's Avatar
Default Rubbing Grinding Noise From Front
Ok, I thought I figured it out, but I guess not. The previous problem: rubbing grinding noise when making right turns. I changed my brake pads today. Problem solved. Second problem: driving straight and slowly and makes the sound of a thin piece of metal either dragging on the ground or rubbing against something. I thought it might have been the dust shield rubbing against the rotor, but it's not. It might be my axle as I am lazy to change one with a bad boot, but it's not clicking. So I can't figure out why my car is making that noise.
Old Aug 16, 2005 | 08:46 PM
BenzTek134's Avatar
Default Re: Rubbing Grinding Noise From Front (BlueIntegraBoy)
check closely sounds a lot like dust sheild rubbing on your rotor bro. i know u mention u checked but check very well not many things down there can cause your car to make that type of sound while turing.
Old Aug 16, 2005 | 09:19 PM
Default Re: Rubbing Grinding Noise From Front (BenzTek134)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenzTek134 &raquo;</TD></TR><TR><TD CLASS="quote">check closely sounds a lot like dust sheild rubbing on your rotor bro. i know u mention u checked but check very well not many things down there can cause your car to make that type of sound while turing.</TD></TR></TABLE>
I'll check again, but it's not when I'm turning. Only driving straight.
Old Aug 16, 2005 | 09:30 PM
j87w's Avatar
Im willing to bet its a wheel bearing.
Old Aug 16, 2005 | 09:36 PM
95jeremie's Avatar
Default Re: Rubbing Grinding Noise From Front (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">Im willing to bet its a wheel bearing. </TD></TR></TABLE>
sounds like the problem to me
Old Aug 17, 2005 | 01:08 PM
Nvm, it is my axle. LOL. Gonna change it this weekend.
Old Aug 18, 2005 | 08:26 PM
Nvm, its not my axle. I just changed it today and still makes a clanking noise.
Old Aug 19, 2005 | 03:46 PM
j87w's Avatar
Check your wheel bearing.
iCollectStraws
Jun 13, 2009 11:13 PM
phyzJunkieCivic
Apr 3, 2007 04:50 PM
A is 4 PiMp
Sep 29, 2006 07:29 PM
okaycivic99
Dec 18, 2005 01:12 PM
Origin
Aug 29, 2004 10:16 PM
