Removing door panel on 96 accord?
Old Aug 16, 2005 | 08:08 PM
honest.hank's Avatar
Default Removing door panel on 96 accord?
something is up with the power lock on the front passenger door of my 96 accord, so i thought i would poke around. however, i cannot seem to get the door panel off. i see one screw in the pocket with the door handle, and another screw in the part of the door where the p/w and p/l switches are. the door panel still feels like it's on there pretty good. is there another screw somewhere that i missed?
Old Aug 16, 2005 | 08:18 PM
HaOcNcDoArd96's Avatar
Default Re: Removing door panel on 96 accord? (honest.hank)
There are a ton of clips on the other side of the door panel. Just pick a corner at the botton and slide your hand in and slowly pull out. You will here a popping sound but thats a good thing. you also may break a few clips if your not careful.
Old Aug 16, 2005 | 08:24 PM
Default Re: Removing door panel on 96 accord? (HaOcNcDoArd96)
thanx HaOcNcDoArd96, i will give that a shot tomorrow
Old Aug 16, 2005 | 08:55 PM
deserthonda's Avatar
did u remove the inner door handle??? if hot u have to tatally remove it once the screw if off u need to slide handle to remove it i believe toward the frt of car once done u got to unclip the rod for the door latch ,,
Old Aug 17, 2005 | 05:02 AM
Default Re: Removing door panel on 96 accord? (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">did u remove the inner door handle??? if hot u have to tatally remove it once the screw if off u need to slide handle to remove it i believe toward the frt of car once done u got to unclip the rod for the door latch ,,</TD></TR></TABLE>
thanx for the info
i hope i dont break anything
Old Aug 17, 2005 | 07:55 AM
SiEcO187's Avatar
Be sure to take of the black protector opposite your power or manual rear view mirrors and there is also a small push in plug that is almost underneth the black protector you need to take that out aswell to remove the panal.
curvenut
Nov 4, 2013 05:21 PM
Honda CA
Jun 29, 2010 09:38 AM
todd.ludwig
May 1, 2006 02:27 AM
garrybloom
Jan 24, 2005 12:42 PM
