wtf - 4 bolts in rotor
Old Aug 16, 2005 | 06:52 PM
7808's Avatar
Default wtf - 4 bolts in rotor
do these 4 bolts in my rotor hold the actual disc on or does it just hold that piece that has the wheel studs in it? cause i just rounded one of the 4 like an ***. all i was trying to do is get my disc off...
also would anyone be able to tell me if the disc comes off without taking the axle not off? i know, why the **** would you have to take the axle nut off the remove the disc, but it really looks like it holds the disc on, that and these 4 bolts i've never seen before on a disc... im try to cut my axle nut off cause the son of a bitch aint comming off otherwise with the tools i have
Old Aug 16, 2005 | 08:04 PM
v4lu3s's Avatar
RTFM
you really hsould have read a walkthough or a manual before you dove into this.
you do have o take the axle nut off and you do need to take the bearing out to get the rotor off, and usually you need an impact gun for all of it.
Old Aug 16, 2005 | 08:07 PM
Orpheus1985's Avatar
Default Re: wtf - 4 bolts in rotor (7808)
haha i read "4 bolts in radiator"... that would've been interesting
Old Aug 16, 2005 | 08:38 PM
7808's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">you really hsould have read a walkthough or a manual before you dove into this.
you do have o take the axle nut off and you do need to take the bearing out to get the rotor off, and usually you need an impact gun for all of it.</TD></TR></TABLE>
**** this
i couldnt find a walk-through and my manual is missing random pages... why the hell would they make it so hard to change a rotor?
Old Aug 17, 2005 | 02:36 AM
7808's Avatar
Default Re: (7808)
anyone ever try those electric impact wrenches? i think i might try one, otherwise get a compressor when i get paid...
Old Aug 17, 2005 | 11:29 AM
F23Coupe's Avatar
Default Re: (7808)
I asked a similar question before. You need an impact SCREWdriver, not an impact driver. Those air and electric impact drivers will strip that screw even more. You need a manual one that you hit on the end with a hammer. They slowly put lots of torque after the screw bit is fully in the screw.
Old Aug 17, 2005 | 12:01 PM
99problemssss's Avatar
and if this is the first time the rotors have been replaced, then prepare for a good ol time. those screws will be fused in there no joke, nevermind the axle nut.
Old Aug 17, 2005 | 12:09 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You need an impact SCREWdriver, not an impact driver</TD></TR></TABLE>
Roger that... It looks like a big heavy screwdriver, with a spot on the end to beat on with a hammer... Each time you hit, it turns ever so slightly, but with tons of torque (well, maybe not tons), and you use that to break those screws loose, then use your regular hand screwdriver to finish...
Old Aug 17, 2005 | 12:15 PM
notoriousB's Avatar
Default Re: (B18C_EJ8)
or just drill the screws out and leave 'em out
Old Aug 17, 2005 | 02:58 PM
Diego Dangers.'s Avatar
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">or just drill the screws out and leave 'em out</TD></TR></TABLE>
or when you buy the compressor, which is always good to have, go ahead and buy a whizzer also, with the whizzer cut a notch to make it look like a big *** flat head screw, no grab your impact screwdriver with the flatheaded tool and try again, happens to me all the time when I take off the rotors of any honda, never on an accord though.
Old Aug 17, 2005 | 04:05 PM
fw190bvi's Avatar
are you talking about the fronts??....those are hub over rotor....
Old Aug 17, 2005 | 05:40 PM
v4lu3s's Avatar
RTFM
why are all you people talking abotu screwdrivers? if 4 bolts are holding the rotod on it is as fw190bvi, a hub over rotor setup as found on 90-97 accords....
Old Aug 17, 2005 | 05:49 PM
Default Re: wtf - 4 bolts in rotor (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the fronts??....those are hub over rotor....</TD></TR></TABLE>
i am, but I just noticed that the guy on top of me said leave them out. I am tlaking about the 4 14s on the face of the hub.
Old Aug 17, 2005 | 06:53 PM
7808's Avatar
stupid...
Old Aug 17, 2005 | 07:43 PM
sauceja's Avatar
Good luck.
on Honda 90-97 accords to get the rotor off the wheel bearing must be pressed out. You must remove the knuckle to get to this. Which means loosening all ball joints and taking the axle out of hub side. You will need a 36 MM socket and I recommend a 1/2" impact or a hell of a big breaker bar to get the axle nut off.
I did this to my 97 accord a few years ago. Also to turn (resurface) these rotors they have to be done on car.
Have fun lol
Old Aug 17, 2005 | 07:59 PM
7808's Avatar
Default Re: wtf - 4 bolts in rotor (sauceja)
man.. what the hell were they thinking, i replaced my axle on my 90 civic, same year as my accord, it was a fricken 30 minute job.. no bolts in the rotors..
Old Aug 17, 2005 | 08:56 PM
sauceja's Avatar
They thought civic being a lighter car didn't need as much stability. I think. Either way yeah it sucks.
Old Aug 17, 2005 | 09:39 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">They thought civic being a lighter car didn't need as much stability. I think. Either way yeah it sucks.</TD></TR></TABLE>
haha, actually i doubt it has anythign to do with stablity, i think the designers at honda were pissed at us or somethign when they designed the 90-97 accord
Old Aug 17, 2005 | 10:13 PM
7808's Avatar
so basicly, its easier to remove the engine from the transmission to do the clutch? or can i pull the axle without removeing the disc?
Modified by 7808 at 1:27 AM 8/18/2005
Old Aug 18, 2005 | 12:52 PM
you can definately full the axles w/o pulling the disc! take off the lower balljoint and the 36mm, give it a little tap to knock it out of the spindle and then pull it out, pry bar helps, make sure not to pull out any of the ujoints.
Old Aug 18, 2005 | 01:05 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">man.. what the hell were they thinking, i replaced my axle on my 90 civic, same year as my accord, it was a fricken 30 minute job.. no bolts in the rotors.. </TD></TR></TABLE>
Actually to replace the axle on a 90 accord is a 10 minutes job... is much easier and fastewr than a civic , on either 1 u got to remove the 32mm civic 36mm acoord axle nut , ball jopint nut + separate ball joint from lower control arm now the easy part on the accord the axle will slide out of the fork easily,,, but on the civic u got to at least remove the fork lower bolt to slip the axle out ///// and to replace an axle u do not have to remove the 4 14mm bolts
Old Aug 18, 2005 | 01:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">so basicly, its easier to remove the engine from the transmission to do the clutch? or can i pull the axle without removeing the disc?
Modified by 7808 at 1:27 AM 8/18/2005</TD></TR></TABLE>
Ok now i am really totally lost as to what u r trying to do,,,,,,what does the clutch disc have to do with removing an axle???,, i was assuming u r trying to replace the frt rotors ... if so let me know i will walk u through it step by step
Old Aug 18, 2005 | 06:52 PM
sauceja's Avatar
Default Re: wtf - 4 bolts in rotor (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
haha, actually i doubt it has anythign to do with stablity, i think the designers at honda were pissed at us or somethign when they designed the 90-97 accord </TD></TR></TABLE>
Yeah I would rather turn rotors off the car any day but it is still not too hard. Just get a milk crate and have a seat. wait 10 minutes and carve some more.
Old Aug 18, 2005 | 06:54 PM
7808's Avatar
Default Re: wtf - 4 bolts in rotor (deserthonda)
well my passenger side axle is going anyways, and my rotors are warped, but yes, i am just trying to change my clutch.. its sounding like i need a compressor or this aint gona happen. sucks cause i cant afford to pay to have it done and im stuck riding my motorcycle, today i had to ride to work in the rain,scary on a sport bike
the car was a gamble, bought at an auction for cheap.
Old Aug 18, 2005 | 06:59 PM
7808's Avatar
wait.. i dont have to get the rotor off to pull the axle? hell yes.. maybe its not as bad as i thought... i was almost giving up
