Location of the IAC(idle air control) sensor...
Old Feb 22, 2002 | 11:07 PM
rockwilda's Avatar
Default Location of the IAC(idle air control) sensor...
need help locating this sensor on the skunk2 mani. on a 00 gsr.
im throwing a CEL 14 which is a defective or unplugged IAC sensor. TIA
Old Feb 23, 2002 | 07:47 AM
Its_real&its_spectacular's Avatar
New User
Default Re: Location of the IAC(idle air control) sensor... (da_rockwilda)
It's actually a valve, not a sensor. I suppose I could go out and look but it's too early. Look for a mostly aluminum piece held to the intake manifold by 2 10mm or 12mm head bolts and with a wire connector going to it. it'll be close to the throttle body and on the firewall side of the intake manifold. (that's where it is on the R...)
It's been a while since I had one off but you might have pinched the black o-ring that seals it. That's what meters how much air enters then engine when idling, instead of keeping the throttle plate open so also look for other potential air leaks (injector seals, intake manifold gasket, throttle body gasket, throttle body sticking open, vacuum lines not plugged) if you can't find anything wrong with the IACV.
http://cgi.ebay.com/ebaymotors/aw-cg...669289&r=0&t=0 Follow this link, the 3rd and 4th last pics show it, just below the Q3A stamping... That's what it should look like.
Old Feb 23, 2002 | 08:40 AM
under_psi's Avatar
Default Re: Location of the IAC(idle air control) sensor... (Its_real&its_spectacular)
idle air control valve is on the throtle body facing the firewall....as simple as that
Old Feb 23, 2002 | 09:21 AM
rockwilda's Avatar
Default Re: Location of the IAC(idle air control) sensor... (T.O.tegs)
thanks guys! ill go look and see whats up with it
Old Feb 23, 2002 | 09:43 AM
rockwilda's Avatar
alright, i fixed it!!!!!! anyways, it wasn't even the "sensor" it was just a plug i didn't seal up when i swapped out for the skunk2 manifodl. thanks for the help
Obama
Sep 21, 2007 11:38 AM
24rex
Aug 22, 2007 08:10 PM
Cuda70
12
Aug 16, 2006 05:01 AM
Inaniac
Aug 21, 2002 07:09 PM
rockwilda
Feb 23, 2002 06:00 AM
