For all,Feel free to share !!!!
All who have or have had experience with a D16 (Z6),(Y8).
What kind of HP(@ torque) and time slips, have you produced with this motor?Any info is welcome! Examples mods,weight,HP,Torque,time slips,gearing,wheels & tires,etc... I'm not looking to be a drag king. Just trying to find out what kind of performance I could get from a D16.Shooting for 14's to 13's times.Is that a achievable goal with a D16?
P.S. I know alot of people are going to tell me to go with a B16 but, I'm looking at the D16 right know. But feel free to add your info as listed above on a B16 as well.
Later-HC4G
Later-HC4G
yep, ur right i am going to tell you to go with a b16 for 14's. if you want more than that look to sink at least 2 grand more into a b16 OR get a frankenstein. to this day i will never understand why ppl build single cams. i know they are cheep, but geez we all know that this is an expensive hobby.
You could be in the 14's with a z6 in a crx. 6-8 psi you could easily be in the 14's. I'm piecing together a turbo for my z6 in my crx right now. We'll see what it runs after I get it on.
Yager-
Yager-
I'm using the D16A6 because in the class that I autocross, I have to keep the stock motor... There are guys running in CSP though who are getting 160HP from the D16a6....
Dan
Dan
Ain't nothin wrong with the SOHC. It's got what, a 90mm stroke? It's not gonna rev as high as a B-series so the peak numbers are always lower, but you can get good power throughout the rev range.
i was running high 14's with a mini me setup in my 92 hatch, w/ a stripped car. In a rex, slap a y8 on you block, with an si or dx tranny and z6 ecu, you should be high 14's easy
The D16 is a great motor.. bullet proof IMO. If you build it right, it can be very rewarding. While im not a big fan of the mini me setup (had lots of problems with mine and felt a little sluggish) if you tune it right, im sure youll be able to squeeze a good amount of power out of it.. I bought another d16a.. milled head, port polish.. it runs really strong.. and i expect to run even stronger when i build the bottom end and slap on a turbo.. The main difference i have had between a b16 and a d16 is the top end.. after 6000rpm the b16 pulls like no tomorrow..
Spooled1.6L
Jan 19, 2004 11:48 AM
