Tell me about 87 CRX's
Old Aug 16, 2005 | 05:48 PM
Neren's Avatar
Default Tell me about 87 CRX's
How are they with upgrades/swaps, lots available? howmuch gas milage do they get, any problems i should look out for if i got one? i might be getting one soon and am just trying to get all the info i can.
Old Aug 16, 2005 | 07:45 PM
teknohatchie91's Avatar
Default Re: Tell me about 87 CRX's (Neren)
d16a1 is the most common engine swap if and only if it's an Si.... they come from the older integras...
Old Aug 17, 2005 | 07:35 PM
Neren's Avatar
the d16a1 is the only swap available for it?
Old Aug 17, 2005 | 07:55 PM
. M i c h a e l's Avatar
dotmichael to you
Default Re: (Neren)
http://www.redpepperracing.com
/thread
Old Aug 17, 2005 | 09:42 PM
90sedan's Avatar
If you can try and get a 2nd generation crx. 88 - 91
Simply because there are tons more upgrade and swap possibilities.
Old Aug 17, 2005 | 11:10 PM
davens's Avatar
Default Re: (Neren)
Look for an 85 Si for the full weight benefits. Stick with a Si/MPFI because the factory carb'd Civics/CRXs will not lend themselves to modifications so easily.
The D16a1 bolts in makes 118 hp...a nice improvement.
It also bolts in the older browntop ZC that makes 133hp...a full five hp more then the blacktop ZC.
There are mount kits for B-series swaps.
Old Aug 18, 2005 | 03:41 AM
StorminMatt's Avatar
Default Re: Tell me about 87 CRX's (teknohatchie91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknohatchie91 &raquo;</TD></TR><TR><TD CLASS="quote">d16a1 is the most common engine swap if and only if it's an Si.... they come from the older integras... </TD></TR></TABLE>
You don't need an SI to do a swap. Although it makes the job easier to swap on the SI, the lower trim CRXs will work as well. They just require MUCH more electrical and fuel system work. However, their extreme light weight makes the effort worthwhile.
Old Aug 18, 2005 | 07:53 AM
driveahonda's Avatar
plastic fenders
Old Aug 18, 2005 | 10:01 AM
Smokinsax's Avatar
The Boot
Default Re: (.MichaeL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .MichaeL &raquo;</TD></TR><TR><TD CLASS="quote">http://www.redpepperracing.com
/thread</TD></TR></TABLE>
lol
I used to have an 87 Civic Si that a B20B/VTEC swapped into it and it was super dope. Just another option I guess...
Dont let anyone discourage you on getting a 1st gen CRX; there is a TON of upgrades available!
Modified by Smokinsax at 10:37 AM 8/19/2005
Old Aug 18, 2005 | 06:19 PM
sam385's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda &raquo;</TD></TR><TR><TD CLASS="quote">plastic fenders</TD></TR></TABLE>
and a plastic front mask that is often cracked.
the 1st gen CRX is a really fun car to drive
Old Aug 19, 2005 | 06:22 AM
vtecn8ive's Avatar
Default Re: (sam385)
yay my 85 just got towed now I am on the look out for a southern state 84-85 CRX nice recessed lights and lighter weight with the 5lbs crash rated bumper reinforcments can't go wrong.
You can swap d16a1, zc (1st gen!!!), b-series, h-series has been done, and 88/newer have been swapped in just takes lots of work.
-Shane
Allistah
Apr 9, 2006 08:57 PM
LotsofPar
Apr 21, 2005 08:11 PM
the niz jiz
11
Sep 30, 2004 05:50 PM
dra600n
Aug 14, 2003 09:10 AM
