this is a very stupid question about an accord
ok guys....my car didnt come with a owners manual....and i was trying to figure my gas milage out...how big is the gas tank on 92' accord EX
My 93 is aprox. 17 gallons man. He just wanted to know dude. GEEEZZZZZ. lol I will check my manuel for you and post later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee »</TD></TR><TR><TD CLASS="quote">Don't worry about the size of the tank. The gas pump will tell you how much gas you have used.</TD></TR></TABLE>
Easy way to figure exact gas mileage...
1)fill tank
2)reset trip meter
3)drive for a few days
4)make a note of the mileage on your trip meter
5)fill the tank back up and note the number of gallons
6)Now divide the number of miles by the number of gallons and you have true mpg.
1)fill tank
2)reset trip meter
Better make this after full tank use of gas gives you more average mileage figure.
If you top off every time you pump fuel, right down the trip mileage and devide that with the gallon. It should give you any where from 20 to 30 miles per gallon.
My worst was 24 and best (driven whole tank on HWY) was 35 mile per gallon.
Check it out!
Try to park at the same pump on both fillups so the tank is in the same position both times. (not leaning away from pump on one fillup and towards the pump on the other fillup) It could mean alot if the parking lot is on a slant, which most are, at least a little for water drainage. I doubt if it would be exactly 17 gallons, even if the tank is bone dry.
Here you go if you still wanted the answer (sorry, spacing is screwed)
1990-93 Honda Accord: Specs & Safety
Vehicle Dimensions
Specification 2-door coupe 4-door sedan 4-door wagon
Wheelbase, in. 107.1 107.1 107.1
Overall Length, in. 184.8 185.2 186.8
Overall Width, in. 53.9 67.1 67.5
Overall Height, in. 54.1 54.7 55.1
Curb Weight, lbs. 2738 2733 3139
Cargo Volume, cu. ft. 14.4 14.4 64.6
Standard Payload, lbs. -- -- --
Fuel Capacity, gals. 17.0 17.0 17.0
Seating Capacity 5 5 5
Front Head Room, in. 38.8 38.9 39.0
Max. Front Leg Room, in. 42.9 42.6 42.7
Rear Head Room, in. 36.5 37.5 37.6
Min. Rear Leg Room, in. 32.3 34.3 34.1
http://auto.consumerguide.com/...ecs/
Vehicle Dimensions
aleks77
Jun 14, 2005 04:47 PM
