project Lsvtec ?uestion
Old Aug 16, 2005 | 04:28 PM
tuanhoprosk8's Avatar
Default project Lsvtec ?uestion
so i blew my pistons on my b18a1 block... I have a jdm b16 a2 head that has a port N polish skunk 2 cam/gears/Itr manifold and some retainres...i want to build a LS vtec... what should i do to the block to make high compression?
well actually im not sure if i have skunk 2 cam gears. some guys just hooked me up with the head and didnt tell me what he had.. it has aftermarket retainers bc i can see them.. but how can you tell if you have aftermarket cams and vaulve springs??
what kind of pistons should i get? b16, ctr, itr??
should i sleeve my block?
what should i do to the block?
what kind of head gasket do i use
kinda a low budget.. under 500 plz
Old Aug 16, 2005 | 05:19 PM
unknown0001's Avatar
Default Re: project Lsvtec ?uestion (tuanhoprosk8)
=depending on what compression you want to run and the ammount of tunning you can be safe and I belive you can run p30 pistons to have a good setup
-Why would you sleeve your block?
-Hone the block thats about it
also take appart the head and check the valves/retainers for any markings that would lead to them being aftermarket
Modified by Mr.RHTuner at 3:17 PM 8/17/2005
Old Aug 16, 2005 | 05:30 PM
sik civic's Avatar
I'll take a stab at this since I've done this twice.
$500 bucks...well...
B16A pistons on those rods (as long as B18B and B18A rods are the same length) Will give you 11.63:1 compression.
And B18C5 pistons will yeald 11.3:1 compression.
I'm not sure of B16B pistons, I haven't used them.
No need to sleeve, besides you don't have the money.
That's where my knowlege ends...
Old Aug 16, 2005 | 05:45 PM
I got a honda's Avatar
Default Re: project Lsvtec ?uestion (sik civic)
i believe pr3 pistons will give him 11.5 with a p72 head..since his is b16 it will look more like 11.2 ......and as far as b16b pistons on those ls rods will give him 12.0
Old Aug 16, 2005 | 05:59 PM
Default Re: project Lsvtec ?uestion (iluvboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">i believe pr3 pistons will give him 11.5 with a p72 head..since his is b16 it will look more like 11.2 ......and as far as b16b pistons on those ls rods will give him 12.0</TD></TR></TABLE>
That's pretty good...11.2 compression isn't too bad
Old Aug 16, 2005 | 07:31 PM
sik civic's Avatar
Isn't it a PR3 head (B16A)?
Old Aug 17, 2005 | 01:57 PM
yeah a pr3 head is b16a... why do i want more compression?
Old Aug 17, 2005 | 01:59 PM
o yeah.. i ment block guard.. not sleeve..... should i block guard my **** too.. what kind of head gasket shoud i use
Old Aug 17, 2005 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik civic &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it a PR3 head (B16A)?</TD></TR></TABLE>
Sorry got confused.
Meant P30 pistons bring it to around 11.2/.5 - 1 compression
Old Aug 17, 2005 | 02:48 PM
Finger Lickin' good's Avatar
Default Re: project Lsvtec ?uestion (Mr.RHTuner)
ARP connecting rod bolts -70
ARP head studs -70 (optional)
Balance the LS crank -175
micropolish is optional -40
B16 rods are too short, keep the LS. More work has to be done to use vtec rods, different bearings.
Tap block for vtec/vtec line -200
P30 pistons -200
A couple hundred more and youll be able to rev higher, take advantage of all motor set-ups.
Old Aug 18, 2005 | 10:05 AM
Default Re: project Lsvtec ?uestion (D-CeReaL#4)
im still figuring out wht kind of pistons i should get.. my friend will sell me some eagle rods but he used it on a turbo ls? would i be able to use those with some kind of v tec pistions?? what ones would be the best?
Old Aug 20, 2005 | 10:41 AM
anyone???
Old Aug 20, 2005 | 06:02 PM
HondaCivicSiR1's Avatar
go with p30's or pr3's, as for the rods if they are cheaper then what it would cost to have your ls rod shot peened, then i would say get them if not then don't waste your money on rods that are that are heavier then stock one's
here is some thing to check out; http://www.zealautowerks.com
Old Aug 20, 2005 | 09:33 PM
Default Re: project Lsvtec ?uestion (HondaCivicSiR1)
well i got the egale rods for for 40 bucks!!! so might *** well use them right?? yeah i kinda want to go with the p30's because my compression might be 12:1.... if i use thouse pistons...would i be able to use the ctr pistons??
Old Aug 22, 2005 | 09:22 AM
you can use pct pistons (ctr) but ur gonna have 12.3 compression!.........just go with pr3 or p30.... pr3(usdm b16) will give 11.6 while p30(jdm b16) will give you 11.8... use oem head gasket...
ivan93egreppin210
22
May 6, 2011 05:08 PM
RomesEM1
Jan 13, 2010 09:34 AM
MrXclusivE
Aug 12, 2009 03:15 PM
96ls_vtec_teg
Jan 27, 2008 07:28 PM
Nikos
Jul 2, 2003 08:59 AM
