lowering springs
I got these goldline lowering springs from my friend and i was wondering if there is anything i should know before installing them on my 02 rsx s...i was wondering if anyone has any suggestions or even any instructions on installation?thanks
after you take off the wheels, you're going to take off two big bolts, which connect the shock strut and the brake hub assembly. be VERY careful when you take out those two big bolts. the axle can slide out of the transmission. and when that happens, it's a pain to put back in. what i suggest is that you have someone hold the axle in place when you take out the two bolts.
i recently installed springs and i had a lot of trouble because of the axle. contact me if you have any questions
The axle shouldn't have slipped out if you had axle nuts on it. It is also easier if you take the middle 17mm bolt off before you take the three 12mm bolts off.
