!! 1995 Accord EX INTAKE INSTALL !!
1995 Accord ex
f22b1
There is what looks to be a sensor mounted to the back of the butterfly valve box..... Will this throw a light???? What is this thing????? And how many lines need to be capped total in the installl
http://www.we-todd-did-racing....5NTQx
c = butterfly valve box
b = where this sensor mounts thats attached to the box...
thanks
f22b1
thanks
i took EVERYTHING out, including the lil sensor box. on my intake it only had one outlet for the vacuum line, but you have 2 lines when you take out that sensor box..
i just used a screw to plug the line.
no lights thrown. just a louder car
yea with aem cai.. i took out every plastic hose from stock airbox.. as for that lil eleectical plug it just sitting there.. i found a nice like clip to hold it.. its not plug into anythign tho i.. its just there..
Also on another note, thanks for your help guys!!! I have the first arm from a CAI ...can this arm of the intake be used for SR or is the SR slightly differnt to fit the filter??? It seems it would be a close tight fit behnid the battery...Also....I only have one spot on the pipe for a line to be run, not two.........
-- how many TOTAL lines need to be capped on the entire install
-- Will the first arm of a CAI work as a SR?
thanks
thanks
if the filter fits on the arm and it fits behind the battery yea you can use it for a sr.. as for how many lines go into your intake.. mine only has one vacume line.. running from the top of the valve cover to the intake..
Marcos707honda
Feb 2, 2010 10:40 PM
