No Brakes...
Old Aug 16, 2005 | 02:06 PM
Civd16y8's Avatar
Default No Brakes...
Hey guys Im lost on this one. I have a 93 Vx hatch and the brakes suck on it. They dont grab until almost the floor. I checked all the brake pads and rotors they are all good. I put 3 different master cylinders in it bled all the lines still no brakes? When the car is running and I pump them it makes it idle funny. Like from 1g to 2g fluctuating? Ive done everything someone please help me out here!!!!
Old Aug 16, 2005 | 06:48 PM
kkim's Avatar
Default Re: No Brakes... (Civd16y8)
did you bench bleed the master cylinders before installing them?
Old Aug 17, 2005 | 12:34 PM
Civd16y8's Avatar
Default Re: No Brakes... (kkim)
Ya I did, with every master cylinder before installing we did. Im so lost...
Old Aug 17, 2005 | 02:26 PM
kkim's Avatar
check your brake booster as it is assisted by vacuum and it sounds like you might have a leaky line or blown diaphram in it.
Disconnect the vacuum line from the intake manifold to the booster, plug the line at the manifold and see if stepping on the brake changes the idle. I bet the idle stays the same. From there, you need to check out what part of the booster is bad. I know there is an inline one way valve in the vacuum line... that may be bad. If not, most likely the booster diaphram.
Old Aug 17, 2005 | 02:44 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civd16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys Im lost on this one. I have a 93 Vx hatch and the brakes suck on it. They dont grab until almost the floor. I checked all the brake pads and rotors they are all good. I put 3 different master cylinders in it bled all the lines still no brakes? When the car is running and I pump them it makes it idle funny. Like from 1g to 2g fluctuating? Ive done everything someone please help me out here!!!!</TD></TR></TABLE>
I have a very very similar problem. But I think my break booster is OK. I'll monitor this thread but if you come up with anything let me know too. This is dangerous.
Old Aug 17, 2005 | 03:42 PM
Civd16y8's Avatar
Haha tried it, I took out the little grey piece that goes from the vaccum line to the brake booster. I had really good vaccum and when I did that the brakes were hard like they should be. Tried a different little grey piece off another eg no difference at all....Thanks for the help lemme know if u got anything else...
Old Aug 17, 2005 | 04:03 PM
kkim's Avatar
then i would start suspecting a bad brake booster w/ something wrong internally.
Old Aug 17, 2005 | 07:02 PM
Civd16y8's Avatar
THAT WOULD BE THE BLACK CIRCLE BOX THAT THE MASTER CYLINDER CONNECTS TO RIGHT?
Old Aug 17, 2005 | 07:04 PM
kkim's Avatar
yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civd16y8 &raquo;</TD></TR><TR><TD CLASS="quote">THAT WOULD BE THE BLACK CIRCLE BOX THAT THE MASTER CYLINDER CONNECTS TO RIGHT?</TD></TR></TABLE>
http://autorepair.about.com/cs...a.htm
http://www.procarcare.com/incl....html
Old Aug 18, 2005 | 03:39 AM
Paprika's Avatar
Can someone explain to me why a bad break booster or how a bad break booster can affect how far you have to push the pedal to slow down? I'd think that if the booster was bad it'll just be harder to push the pedal down since you don't have the vaccume assistance. No?
Old Aug 18, 2005 | 10:57 AM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civd16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Haha tried it, I took out the little grey piece that goes from the vaccum line to the brake booster. I had really good vaccum and when I did that the brakes were hard like they should be. Tried a different little grey piece off another eg no difference at all....Thanks for the help lemme know if u got anything else...</TD></TR></TABLE>
Paprika- Yes, I misread Civd16y8's answer on checking the booster. He needs to check if his idle still varies from 1-2k, when he has the booster vacuum line removed and the intake manifold spigot plugged, while the brakes are being pumped. Sorry for the confusion. He left out that piece of information and I assumed he was saying it was okay.
Old Aug 18, 2005 | 02:28 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">
Paprika- Yes, I misread Civd16y8's answer on checking the booster. He needs to check if his idle still varies from 1-2k, when he has the booster vacuum line removed and the intake manifold spigot plugged, while the brakes are being pumped. Sorry for the confusion. He left out that piece of information and I assumed he was saying it was okay.</TD></TR></TABLE>
Yeah I'd think if it still varies it's an electrical issue, no?
Old Aug 18, 2005 | 03:00 PM
kkim's Avatar
Default Re: No Brakes... (Paprika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I'd think if it still varies it's an electrical issue, no?</TD></TR></TABLE>
Possible, but hard to say at this point. If he disconnects the booster completely from the intake mani, plugs the the hole in the mani, then has no weird idling problems, I would think it safe to look at the booster (and associated parts) as the possible source of his brake and idling problem... though he may have multiple problems, too.
I try to troubleshoot one problem at a time so as not to end up confusing the symptoms.
tj4fa
Feb 24, 2019 11:22 AM
DUKE LADUKE
25
May 10, 2011 09:21 AM
SideFX
Sep 18, 2009 05:25 PM
AcidGord
Dec 24, 2003 10:38 AM
