Anyone Have A 98 spec N3E JDM ITR Tranny?
and swapped out the GSR 4th and 5th out for the EM1 Si 4th and 5th? Just wondering whether any modifications need to be done, or if these gears are interchangable?
Also, kind of curious. Are all the synchros on the N3E tranny dual cone, or is it just 1st and 2nd?
From: gravity rides everything...everything will fall, se GA/ne FL
yes the gears are interchangeable (4&5 set that you mentioned). it is a direct swap. despite what you may hear, only second gear synchro is dual cone.
