Low Idle Porblemo!!
Old Aug 16, 2005 | 12:07 PM
joshcivic00's Avatar
Default Low Idle Porblemo!!
once again,a low idle problem!my car seems to idle around 3-400rpms lower(goes down near 0 when car is warmed up and idleing) then what it should!!also,a local tuner told me that my o2 sensors are out of spec and that my Cat is clogged!i was also throwing a CEL code 45(failure to fuel system due to being too lean or too rich)i believe that the o2 sensors are all that controls the fuel mixture and could be affecting the rpm's!anybody know if replacing o2 sensors and high flow CAT could fix this problem??if not any ideas(i also am running a greddy kit with everything installed correctly;professionally)i have an 00 Civic ex
Old Aug 16, 2005 | 12:57 PM
meanTheDope's Avatar
Default Re: Low Idle Porblemo!! (joshcivic00)
try adjusting your idle...and try advancing your timing...that fixed my problem.
93civiconair
10
Feb 5, 2012 07:32 PM
bricks2k4civic
Honda Civic (2001 - 2005)
May 21, 2006 09:44 AM
prelude2005
Oct 30, 2004 08:03 AM
mr. carpenter
Feb 8, 2004 12:03 PM
