Anyone know what this noise may be from?
After I shift then hold in the accelerater there is a very high pitched squeel..it does not eer change pitch and it just appears then sharply dissapears. I can make it come and go or stay as long as I want by holding in the accelerator pedal at a certain point. It almost sounds like a belt squeel but there would be a fade in and a fade out. It is on the right side (passenger) and my friend thinks it sounds like a high frequency pitch. Its odd and does not affect anything that I am aware of. The noise seems to come from where the batery and fuse box is. There is a cold air intake there also. I thought it may be a vacum hose or the air filter. I was jsut hoping its not the tranny. It is a CRX 89 si. Any other info you need to try to figure this out I will provide. I hope some one knows what the hell I'm talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dorksk8tr3 »</TD></TR><TR><TD CLASS="quote">There is a cold air intake there also.</TD></TR></TABLE>
thats whats causing it.......perfectly normal
I think it would be the throttle body. I have never heard an intake whistle like this and its at an exact amount of acceleration. only when I push the gas pedal at the right amount. THanks for your input.
that was our original thought...it sounded like a high frequency noise..so i suggested a groung wire from the side some where....we didn't check them all....I guess I would just look for a ground thats not fully contacted with maybe some burn marks....thanks for rekindling our original thought its nice to have someone else think this too... I will check all the possible ideas suggested so far.
In European D16A9 Dohc engines have a little whistle if you listen very hardly. Between 3000 and 6000.
I think its nice whistling sound, never heard after installing a cone.
Canadian_EF
Jun 9, 2009 11:16 AM
sirminder
Apr 6, 2003 04:04 PM
