97+ prelude 5spd shifter mechanism/cables the same as 92-96 Prelude and 90+Accord?
Old Aug 16, 2005 | 08:15 AM
Boosted Power's Avatar
Default 97+ prelude 5spd shifter mechanism/cables the same as 92-96 Prelude and 90+Accord?
Hi,
I need some help.
I'm thinking about swapping an H22A4 from the 97+Base model Prelude 5spd into my 94 Honda Delsol S.
Was wondering if the shifter cables are the same from the 97+Prelude Base model and the 92-96 Prelude and 90+Accords? I'm assuming that 97+Preludes still use shifter cables.
Also, would I be able to use the 92-96 Prelude and 90+Accord cable/shifter if the 97+Prelude ones dont fit?
Other then a little rewiring work, I should be able to swap the 97+Prelude motor/tranny into the EG just like any other H22A swap right?
Please help.
Thanx,
-Lor
Old Aug 16, 2005 | 06:18 PM
v4lu3s's Avatar
RTFM
yeah it does have cables the shifter is differnet though with a lot of plastic on it. the earlier lude one is more metal. the cables are all slightly dif flengths, and usually it is best to use teh mathicng cables and shifter, but with creativity you can often mix and match them some.
beenba
Mar 27, 2015 03:13 AM
BrizzlEK
Sep 9, 2009 01:47 PM
Freeltec
Apr 19, 2006 08:15 PM
