Car won't start...any ideas?
So my car broke down last night.
I was driving, pressing on the gas pedal after an exit and the car just completely stopped. So I pull over, and try to the start the car. I mean, all the lights work and the car trys to crank but I feels like it's not getting gas to ignite.
What could it be? I tried turning the ignition while putting opening the throttle all the way and that seems to get it to sputter and idle at about 2-3 rpms...but my foot has to be on the pedal to keep the car alive. When I let off, it immediately dies.
What do you guys think it could be? I have an 87 CRX, oldie but goodie.
thanks guys.
thanks guys.
if you know you have spark and your timing is right.. then i would check the injectors with a noid light and work your way back could be the fuel pump relay goin out on you.. try tapping it while starting see if that helps..
ttcheung97
Aug 24, 2020 06:31 AM
watacivic
Aug 4, 2007 11:42 PM
