why would i use a p72 over a p28 in my allmotor application?
Old Aug 16, 2005 | 04:37 AM
Black R's Avatar
25 Year Member
Default why would i use a p72 over a p28 in my allmotor application?
is there any legitimate reason? assume it's a vtec motor with itb's.....
Old Aug 16, 2005 | 05:11 AM
boosted k20's Avatar
Default Re: why would i use a p72 over a p28 in my allmotor application? (Black R)
if u have a B series motor, then the P72 has fuel and ignition mapping for it. P28 has tables for a SOHC motor. it dont matter too much, but if i were u, i would get a OBD1 P28 or P72, socket it and run CROME for their ITB support
Old Aug 16, 2005 | 06:31 AM
Black R's Avatar
25 Year Member
Default Re: why would i use a p72 over a p28 in my allmotor application? (boosted k20)
I've already got a socketed and crome tps mapped p28.
I've already got a socketed and crom tps mapped p72.
I was thinking of maybe using the p72 just for the fact that it has a knock sensor and I could possibly use that for my datalogging/ tuning - especially with my high compression setup that I'm building.....
Old Aug 16, 2005 | 06:44 AM
blundar's Avatar
the knock sensor isn't quite useless, but damn close. If you have a built motor, it's damn useless. The knck sensor is tuned for a rather specific noise, and if you do too much to change that (forged pistons, difference in bore in particular) it ceases to be useful. The reason to use a P72 is for the extra output (IAB) but it's a non-issue with ITBs.
Old Aug 16, 2005 | 06:45 AM
blundar's Avatar
And if you have big cams, you may want to get+install ITB tools plus. It's a little OTT in terms of column resolution, but having the extra rows is making a huge difference on the car with Pro1s I'm working on.
Old Aug 16, 2005 | 07:00 AM
Black R's Avatar
25 Year Member
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">And if you have big cams, you may want to get+install ITB tools plus. It's a little OTT in terms of column resolution, but having the extra rows is making a huge difference on the car with Pro1s I'm working on.</TD></TR></TABLE>
I believe johnzm used itbtools+ on cromepro for the base map he burned for me.
Old Aug 16, 2005 | 07:09 AM
blundar's Avatar
good luck, and rememeber to use the force. Don't be afraid to feed the ****** fuel either. ITBs are very peaky
Old Aug 16, 2005 | 08:45 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">good luck, and rememeber to use the force. Don't be afraid to feed the ****** fuel either. ITBs are very peaky</TD></TR></TABLE>
haha, I am very concerned re: running out of fuel.....!
Old Aug 16, 2005 | 10:27 AM
machine4321's Avatar
it wouldsnt really matter what ecu you went with on account you need a p30 base for itb tools ? right
Old Aug 16, 2005 | 10:35 AM
Eddiebx's Avatar
imo use which ever you have on hand and is cheaper, beucase in the end they both are pretty much the same thing. seeing as you have both, i'd do a coin toss
Old Aug 16, 2005 | 11:31 AM
id keep the p28 and sell the p72..they seem to have a better resale value
Old Aug 16, 2005 | 01:03 PM
.nate's Avatar
ITB's love fuel. When we converted from a IM to TWM's I had to add shitloads...
Old Aug 16, 2005 | 01:15 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">ITB's love fuel. When we converted from a IM to TWM's I had to add shitloads...</TD></TR></TABLE>AGREEEEEED!!!
Old Aug 16, 2005 | 01:19 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">the knock sensor isn't quite useless, but damn close. If you have a built motor, it's damn useless. The knck sensor is tuned for a rather specific noise, and if you do too much to change that (forged pistons, difference in bore in particular) it ceases to be useful. The reason to use a P72 is for the extra output (IAB) but it's a non-issue with ITBs.</TD></TR></TABLE>
Yeah. I seem to be logging "knock" at half throttle with my setup now. 11.3:1 comrpession with some pretty large cams. USDM ITR pistons though. I put in some 110 octane and STILL logged the same amount of knock.. I think that the knock sensor tends to pick up "engine noise" a little more then anything else at this point. I agree that it is somewhat useless at this point.
tico
Aug 9, 2012 11:00 AM
L_K
Aug 21, 2006 06:59 PM
ice11honda
Jun 23, 2005 09:53 AM
555R
Jan 27, 2003 06:36 PM
IdotheSHOCKER
May 30, 2002 12:31 AM
