Is my compression 2 Low On my built motor ?
Im putting together my gsr turbo engine and i was woundering if you guys think my compression is to low . Im using ross 8-1 compression pistons 84 mm on a sleeved block . My engine builder said it should be around 8.6 -1 with the head on it . I figured i run this compression because im running a t-62 dual ball bearing 70 trim turbo at over 20 psi when im at the track and i want it to be able to withstand the high boost ..... what you guys think > Should i have went with 9-1 >?
ur comp. ratio is totally fine, it may be a little sluggish until boost kicks in but it wont be bad. mine is 8.4:1 and it runs just fine. have fun and good luck.
TehMoonRulz
May 16, 2005 01:15 PM
Death_to_Thieves
Apr 24, 2004 08:46 PM
s0liDyNe
Jul 19, 2003 10:24 PM
