1991 integra rs tranny swap question
Old Aug 15, 2005 | 08:53 PM
blind6's Avatar
Default 1991 integra rs tranny swap question
I currently have the auto tranny.......which manual tranny would be the best to swap for and what are some pointers on the install. Help is greatly appreciated. THANKS
Old Aug 16, 2005 | 12:02 AM
EKboyEK96's Avatar
Default Re: 1991 integra rs tranny swap question (blind6)
Bump. Have the same question!
Old Aug 17, 2005 | 11:13 AM
blind6's Avatar
Default Re: 1991 integra rs tranny swap question (EKboyEK96)
BUMP.......
Old Aug 17, 2005 | 01:32 PM
unknown0001's Avatar
you want to keep the b18a motor or are you swapping that too?
if you want a good tranny, pickup the b16a1 tranny and install that
Since your teg and the b16a1 tranny are both cable clutch, all you really need is the shift linkage and the mount and it should be good to go
Old Aug 17, 2005 | 01:58 PM
projectTeG's Avatar
http://g2ic.com/forums/showthread.php?t=40496
this should handle all your questions....also camp1320 now sells the mount for the auto to manual swap for the 90-93 tegs
Old Aug 17, 2005 | 06:31 PM
blind6's Avatar
Default Re: (projectTeG)
sweet...appreciate the help!!!!!!
Old Aug 17, 2005 | 07:19 PM
UpgradesLLC's Avatar
Default Re: (blind6)
you might wanna make your decision as to what tranny your gonna run based on your mods, i.e longer geared tranny (ls) for turbo app or gsr (short gears) for n/a(and street use)
Old Aug 17, 2005 | 07:28 PM
projectTeG's Avatar
well, the cable ls tranny is shorter than the hydro ls tranny, id say if you dont mind how much you want to spend then, get a b16 tranny with lsd
nicanbeastfool
Mar 31, 2009 09:44 AM
B20TRIZ
Jan 19, 2009 05:08 PM
roadrunn
May 17, 2008 01:36 AM
dipset1
Feb 2, 2006 12:29 AM
2002stockEX
Jun 11, 2003 11:50 PM
