Racing Hart c2evo rims problem help pleaseeeeee!!
Old Aug 15, 2005 | 08:16 PM
vtecvlow's Avatar
Default Racing Hart c2evo rims problem help pleaseeeeee!!
so yeah, i put the rims on, now 1 of the center caps are stuck, it's made of alumnium and i know for a fact that it was cross-tread, being stuck, i know i messed up the treading.. so.. are my rims affected too? What can i do? i dont wanna damage it anymore.. i'm fine w/ buying a new center cap thats np.. and inputs would be appreciated thanks!
Old Aug 15, 2005 | 09:26 PM
vtecvlow's Avatar
Default Re: Racing Hart c2evo rims problem help pleaseeeeee!! (vtecvlow)
bump bump bump
Old Aug 17, 2005 | 04:51 PM
VisualAutoMotoring's Avatar
The C2's had 2 different designs on the threading on the center cap. It was either welded/constructed with the wheel or a add on set screwed in.
If you have the set screwed in type, then your ok those can be replaced but if its part of the wheel i dont think there is much you can do unless the center cap is what is cross threaded.
Old Sep 5, 2005 | 03:14 PM
vtecvlow's Avatar
Default Re: Racing Hart c2evo rims problem help pleaseeeeee!! (Hybrid-Performance.com)
turns out it messed up the tread on the rim -_- so iono whut to do anymore.. i already bought the center cap.. shouldve just bout a whole new rim..
Old Sep 6, 2005 | 03:04 PM
stkd16z6's Avatar
not to hijack your thread, but ill buy that extra center cap from you if you dont need it. if the threads on the center of the wheel arent that bad maybe you can re thread it? although its probably a big size im not sure how you'd do it.
Old Sep 8, 2005 | 09:20 AM
vimsH22's Avatar
hmm! that sux..
Old Sep 9, 2005 | 12:23 PM
vtecvlow's Avatar
Default Re: Racing Hart c2evo rims problem help pleaseeeeee!! (stkd16z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stkd16z6 &raquo;</TD></TR><TR><TD CLASS="quote">not to hijack your thread, but ill buy that extra center cap from you if you dont need it. if the threads on the center of the wheel arent that bad maybe you can re thread it? although its probably a big size im not sure how you'd do it.</TD></TR></TABLE>
pm'd
patotas
Jun 23, 2009 03:11 PM
JUNKIE DUCKY
Oct 2, 2008 07:44 AM
ef9robert
May 10, 2005 11:00 PM
Sprockets
May 8, 2003 01:00 AM
