Sir Headlight Wiring
So 94-97 Accords have 9005/9006 headlight bulb setup. The JDM headlights I bought have a weird configuration of an H3 headlight bulb and a foglight bulb? How do you wire your headlights to the H3 configuration from the 9006/9005 setup?
Are you sure it isn't a H4 low beam and H3? high beam pattern for the SiR headlights?
When you say SiR ... are you referring to the 2-piece 94-97 JDM equivalent or the 1-piece 2001+ JDM equivalent?
If you're referring to the 94-97 2-piece, you can purchase a conversion harness that allows you to use the existing wiring in your car to plug up to the H3/H4 JDM headlights.
AsnRacerX
Apr 21, 2014 12:53 AM
