any tips while pulling my first tranny?
Old Aug 15, 2005 | 07:05 PM
torqueMONSTER's Avatar
Default any tips while pulling my first tranny?
yea i can do all the work. ive just never had to pull a tranny and im used to working on dsms so just lemme know what to encounter while pulling my b16 trans outta my eg. thanks
Old Aug 15, 2005 | 07:28 PM
komat's Avatar
Default Re: any tips while pulling my first tranny? (torqueMONSTER)
not really its pretty basic
its easier if you have two people when pulling and putting the tranny back on
for the axel nut you may need to use a jack to break it loose
use this guild if u get stuck
http://www.c-speedracing.com/h...h.php
Old Aug 15, 2005 | 08:28 PM
MidoriBG96's Avatar
Default Re: any tips while pulling my first tranny? (komat)
Be sure to get the bolt on the underside of the starter, it'll trick ya. Other than that take off the flywheel shield by the oil pan, take out all the bolts and the bolt on the underside of the starter and whalla like butta
Old Aug 16, 2005 | 06:53 PM
Default Re: any tips while pulling my first tranny? (EH2rbg93)
what do you mean take out the axle nut with a jack
Old Aug 16, 2005 | 07:42 PM
freakasis's Avatar
i can only guess he means to put a breaker bar on it and jack it up, because it can be a bitch to get those off. oh they are the same size as the 1st gen dsms. so u prolly have the socket already. 32mm
Old Aug 16, 2005 | 08:26 PM
sudds's Avatar
You do not need to remove your axle nuts, just undo your shock fork and lower ball joints, move the hub out of the way. Then you can just pop the axles out. I just did this on sunday by myself, nothing like a clean virgin tranny from the factory.
Old Aug 16, 2005 | 09:31 PM
Bond's Avatar
Default Re: any tips while pulling my first tranny? (sudds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sudds &raquo;</TD></TR><TR><TD CLASS="quote">You do not need to remove your axle nuts, just undo your shock fork and lower ball joints, move the hub out of the way. Then you can just pop the axles out. I just did this on sunday by myself, nothing like a clean virgin tranny from the factory.</TD></TR></TABLE>
Yup, no need to remove the axel nut's do as said above and just swing the axle out. Did this a couple months ago and it worked very nice.
Old Aug 16, 2005 | 11:36 PM
BoOstedEM1's Avatar
Reall easy..did them like 3 a week starting to get faster at it...now im about to start timing my self....hahaha.
Old Aug 17, 2005 | 12:05 AM
SpydiR's Avatar
I'm surprised nobody mentioned the linkage pin. I think you'll need an 8mm punch for that, it's a total pain in the *** to do by yourself
Old Aug 17, 2005 | 01:23 AM
dohcMONSTER's Avatar
Default Re: (SpydiR)
take the flywheel cover off.....
Old Aug 17, 2005 | 07:54 AM
BoOstedEM1's Avatar
Default Re: (dohcMONSTER)
Also take down the shifter..or disconect from tranny...its also forgoten....ohhhh drain the tranny
Old Aug 17, 2005 | 08:20 AM
Bond's Avatar
Default Re: (BoOstedEM1)
The bitch pin really isn't that bad. WD40 or liquid wrench, tap it, let sit for 30min. Tap it out nice and easy. Should just take some light tapping to get it out.
Old Aug 17, 2005 | 08:26 AM
Sketch_hs's Avatar
make sure you drain the tranny!
have a good torque wrench and please use correct torque on everything!
be sure to grease the TO bearing and fork right... clean everything while your in there too
Old Aug 17, 2005 | 10:19 AM
Jwbetley's Avatar
Yes you do. In fact, both axle nuts and axles have to come off if you want it to be easy. It is a b series and it has the half shaft. Even better, it is a b16 which has the female half shaft, which means you cant pull it out from the axle without releasing the locknuts like you can on a gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR &raquo;</TD></TR><TR><TD CLASS="quote">I'm surprised nobody mentioned the linkage pin. I think you'll need an 8mm punch for that, it's a total pain in the *** to do by yourself </TD></TR></TABLE>
As long as he is not swapping the linkage, he can easily leave linkage on.
Just jack the car up evenly all around and try to get help from someone when removing/ installing the tranny. Those splines are a bitch to get in sometimes, and if you dont get it in all the way and the tranny tilts all of it's weight down, you cluch could bend or crack.
Old Aug 17, 2005 | 01:10 PM
sudds's Avatar
Default Re: any tips while pulling my first tranny? (Jwbetley)
Thats funny, I just unbolted the 3 bolts holding the half shaft and pulled it out of the tranny.
Old Aug 17, 2005 | 02:02 PM
slammed00si's Avatar
you do not need to pull the axle nuts off. i just changed my seals on my b16 tranny i would know. just loop it out and call it a day.
Old Aug 17, 2005 | 03:26 PM
MikeNice's Avatar
don't forget the bolts that hold the starter in. I've seen alot of people forget that and wondering why they can't get the tranny off and also the flywheel cover.
Old Aug 17, 2005 | 04:52 PM
HiProfile's Avatar
Default Re: any tips while pulling my first tranny? (MikeNice)
Both times I tried removing the axle&halfshaft from my b18b in my eg, I *had* to remove the axles from the hubs. In a teg you might have enough room to drop the tranny with the pass. side axle hanging there, but not in an eg. Do it right so you don't get mad later.
Also, heat up the splines in the hubs after you remove the nut. Then soak it in pb blaster or whatever, let it soak for 30mins. Later use at least a 4lbs sledge & big centerpunch to knock the axles out. Out of the 10 axles I've dealt with, only 3 came out with *just* a normal hammer.
Last thing - 2 or more big pry bars will help a lot.
Old Aug 17, 2005 | 05:09 PM
e jay one's Avatar
Default Re: any tips while pulling my first tranny? (HiProfile)
the crafstman 1/2" ratchet trick for the balljoints works great
Old Aug 17, 2005 | 05:12 PM
b20lsvtecCivic's Avatar
go to the parts store and buy a helm book for ur car if u want to do it the rite way
also makes things a whole lots easyier if u are doing it the first time
Old Aug 17, 2005 | 05:36 PM
Default Re: any tips while pulling my first tranny? (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">the crafstman 1/2" ratchet trick for the balljoints works great </TD></TR></TABLE>
please explain this trick to get the ball joint out.
yea i got torque wrenches.
so just take out the axles. move the shift linkage. remove starter bolt, flywheel cover. take off motor mount, and im good to go?
damn this project sounds fun...
Old Aug 17, 2005 | 05:40 PM
cxSHOE's Avatar
check you pm.......
and throw away that chiltons....
Old Aug 17, 2005 | 05:44 PM
Default Re: any tips while pulling my first tranny? (cxSHOE)
thanks for that helms link cxSHOE, much love homie
Old Aug 17, 2005 | 05:55 PM
SirRevvs's Avatar
Don't pull the axle nuts, take out the lower ball joint 17's and unbolt the halfshat from the block and just move the axles out of the way. Jack your car up high enough so you can just slide the tranny out from under the car when you drop it. DO not undo the bitch pin, instead just take off your exhaust hangers and pull the two 12 mm's for the shifter and drop the whole linkage. Other than that just start pulling bolts until the tranny comes loose. Don't undo the rear motor mount bracket form the engine (just take out the 2 19's for the tranny) that way you can just let the engine hang. Good Luck
Old Aug 17, 2005 | 06:20 PM
Default Re: any tips while pulling my first tranny? (SirRevvs)
first, thanks for all the replies, this will help me alot...
and some people say i dont need to pull the axles and some people say i do cause no space in a eg.
and whats the 1/2" ratchet trick to take out the ball joints?
