HELP!!
Old Aug 15, 2005 | 05:54 PM
sycamore
Guest
Posts: n/a
Default HELP!!
ok so i put a ls in my 91 hatch and it pulls to the left(driver side) hard my. alignment looks ok and from what i can see every thing is ok.... so iny one got any ideas ill try it
thanks...
Old Aug 15, 2005 | 06:50 PM
drdisco69's Avatar
Default Re: HELP!! (sycamore)
I wouldn't go by looking at the alignment. It takes a fraction of a degree to make the car pull, and when you have 2 or 3 things working together, it doesn't take much at all. Try rotating the tires, or swap left and right and see if it changes.
Old Aug 15, 2005 | 08:14 PM
b18_crx's Avatar
Default Re: HELP!! (drdisco69)
did you take front crossmember off? i did and needed aligment afterwards.....bad!
Old Aug 15, 2005 | 09:47 PM
Civic138's Avatar
Default Re: HELP!! (b18_crx)
might also be an axle,
my car was pulling hard to one side, the shaft popped out of the place where the bearings hold it in, and made my car pull.
Old Aug 15, 2005 | 09:48 PM
boosted_hatch_216's Avatar
Default Re: HELP!! (Civic138)
get it aligned.
Old Aug 16, 2005 | 10:51 PM
sycamore
Guest
Posts: n/a
yea i took my cross member off three of for times but it is going in for a alignment to morrow and i put new lower control arms in and it helped a little bit but thanks for the help...
Old Aug 17, 2005 | 06:16 AM
CRX T-Si's Avatar
Default Re: (sycamore)
If you gonna put new control arms in then you should Index your bushing or another way of saying it...load them before tighting them.
By this I mean let the car sit at normal right height and then tighten your suspension pieces, All your moving parts needs to be done like this.
I did this to mine and the torque steer is almost 99% gone. Before I did that my **** felt like a fish, just swiming around going from side to side.
knightsef-eg
16
Jan 2, 2010 06:50 AM
car noob
Nov 6, 2008 11:46 AM
JDM_EK_wanabe
Sep 5, 2006 07:18 PM
BoOsTiN Dc2
Sep 5, 2005 12:02 AM
VTECRaZeR
Jan 23, 2004 01:16 PM
