Dealership says throttle body sensor has been tampered with...
Old Aug 15, 2005 | 04:54 PM
is3oo's Avatar
Default Dealership says throttle body sensor has been tampered with...
I'm in the process of returning my motor to bone stock. My car has been running bad lately, so I took it into Acura for a diagnosis. So after they did that, they told me that the TB sensor has been tampered with and that I need to get a brand new one which they quoted me $700 for! They said that once it has been tampered with, it's impossible to get the settings right or something. So is this true? If it is, what's my best choice in this situation? Look for a used ITR TB (but what if it's been tampered as well?) or an aftermarket TB perhaps? I'm trying to keep my car as close to stock as possible if going with an aftermarket TB. I don't really know much about this stuff, so if anyone could help me out, I'd greatly appreciate it. Thank you.
Old Aug 15, 2005 | 05:00 PM
D's Avatar
D
Default Re: Dealership says throttle body sensor has been tampered with... (ITR#293)
Adjust TPS so output voltage is ~.5V closed, ~4.5V WOT.
Old Aug 15, 2005 | 05:39 PM
0554's Avatar
Default Re: Dealership says throttle body sensor has been tampered with... (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">Adjust TPS so output voltage is ~.5V closed, ~4.5V WOT.</TD></TR></TABLE>
ditto
Old Aug 15, 2005 | 06:09 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: Dealership says throttle body sensor has been tampered with... (ALL M0T0R CRX)
Its, not impossible, use DVOM and follow above procedure
Old Aug 15, 2005 | 06:22 PM
jdmvtec28's Avatar
Default Re: Dealership says throttle body sensor has been tampered with... (v-attack)
if that does not work and you need to replace the TPS sensor use a CBR954RR motorcycle TPS sensor, they are identical to ours!
Modified by jdmvtec28 at 10:58 PM 8/15/2005
Old Aug 15, 2005 | 06:30 PM
migs's Avatar
Default Re: Dealership says throttle body sensor has been tampered with... (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">if that does not work and you need to replace the TPS sensor used a CBR954RR motorcycle TPS sensor, they are identical to ours!</TD></TR></TABLE>
LOL, nice!
Old Aug 15, 2005 | 10:41 PM
Kendall's Avatar
I have a spare TPS just laying around if you need one.
Old Aug 15, 2005 | 10:54 PM
is3oo's Avatar
Default Re: Dealership says throttle body sensor has been tampered with... (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I have a spare TPS just laying around if you need one.</TD></TR></TABLE>
Is your TPS adjusted to the correct setting? How do you adjust it? Is it hard to install the TPS sensor? How much?
Also does anyone have a ITR fuel rail and pressure regulator??? Thank you!
Old Aug 15, 2005 | 11:14 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#293 &raquo;</TD></TR><TR><TD CLASS="quote">
Is your TPS adjusted to the correct setting? How do you adjust it? Is it hard to install the TPS sensor? How much?</TD></TR></TABLE>
To adjust the TPS, it has to be on the throttle body. You simply loosen the faseners and turn it back and forth until the voltage is correct. Use a multimeter to ensure correct voltage. Most US market throttle bodies have the TPS's attached with headless screws that need to be notched in order to remove/loosen them. I usually just replace them with standard phillips screws.
Old Aug 16, 2005 | 03:04 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
I also have one lying around. You have to loosen the (cant think of the word) bolts that hold it on, they dont have heads. Take a chisel and notch them and then take a screw driver and hammer and turn them lefty lucy. Once you break them loose you can do it by hand. Adjust as necessary and then use a couple of 10mm to put them back in.
Not hard at all, dealerships refuse to take them off, they make more money saying that the customer has to buy the whole TB.
Old Aug 16, 2005 | 03:08 AM
cool guy name
Default Re: Dealership says throttle body sensor has been tampered with... (walker111)
Oh yea, when installing the new tps, there is a plastic prong on the sensor itself, and two metal prongs in the whole in the TB. The plastic prong needs to go between the two metal prongs in the TB.
&lt;------who let a friend put his tps on while he did something else and wondered why his car was never hitting WOT.
Old Aug 16, 2005 | 03:50 AM
Finland's Avatar
Forget the dealer. There are much better ways to get this resolved. $700 for a TPS? That's ludicrous.
All the info you need is in this thread.
Old Aug 16, 2005 | 08:37 AM
cannan's Avatar
Default Re: (Boondock Saint)
They are quoting you a price for the whole throttle body with sensors. I went through this last summer with my R because the TPS Sensor went bad.
Use all the help that has been given above and you'll save yourself tons of money. You'll have to drill out the pop-rivets that hold the TPS Sensor inplace on the Throttle Body then just use some screws or nuts to secure the new one once the new TPS Sensor is in place and functioning
alupso
Southeast (Sales)
Oct 11, 2008 05:54 PM
yesSiReK
Feb 19, 2008 02:39 PM
civicsi401
42
Mar 24, 2007 05:23 PM
ALLMOTOR ARUBA
Jun 6, 2004 06:16 AM
Redsim
Jun 11, 2003 09:37 PM
