Confused on what to run with 8psi--fuel pump,regulator??
Old Aug 15, 2005 | 04:48 PM
bmoser18's Avatar
Default Confused on what to run with 8psi--fuel pump,regulator??
I am going to be running 8 psi on a 94 GSR and was wondering if i am going to have to upgrade the fuel pump and regulator. I bought DSM 390 injectors and I keep hearing many things about Fuel pumps and FMU's. DO I need an FMU or just an upgraded fuel pump?? help thanks.
Old Aug 15, 2005 | 05:03 PM
mmuller's Avatar
Mad Scientist
Default Re: Confused on what to run with 8psi--fuel pump,regulator?? (bmoser18)
your stock fuel pump should be fine; i would advice against raising fuel pressure as fuel management.
get a boost chip tuned with your 390's
Old Aug 16, 2005 | 02:30 PM
bmoser18's Avatar
Default Re: Confused on what to run with 8psi--fuel pump,regulator?? (mmuller)
I am going to use a VAFC and I want to try to avoid all that other fuel upgrade stuff as much as possible. If I do upgrade my fuel pump to I need to buy a fuel pressure regulator too??
B16CRXT
Aug 29, 2004 11:06 PM
drumking15
May 10, 2004 11:57 PM
ATS*Mark
Nov 4, 2003 05:11 AM
E Swift
May 29, 2002 05:16 PM
Brian_92GSR
Oct 25, 2001 11:27 AM
