what will work?
well i put the coilover sleeves from my old ej coupe on my ef and they fit fine front and back...its just that the spring rates were designed for a heavier car and they dont really work too well on the lighter ef body...the ride was very bouncy and it did not react as well as the old springs under hard cornering...i ended up slamming em all the way just to soften up the ride a little bit...still didnt like em so i put the old springs back on...
suspension kits are designed model specific for a reason...just stick with what is made for your model
The ef should work but if not the suspension from a 91 GSR intergra should fit fine also What engine you got H22? B-16,18 ? cuz the suspention of the factory crx is fine for the h22 and b-16 but the b-18 is hevier so ull need the 91 intergra suspension witch should fit it fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC DrEaMz »</TD></TR><TR><TD CLASS="quote">The ef should work but if not the suspension from a 91 GSR intergra should fit fine also What engine you got H22? B-16,18 ? cuz the suspention of the factory crx is fine for the h22 and b-16 but the b-18 is hevier so ull need the 91 intergra suspension witch should fit it fine</TD></TR></TABLE>
are u serious?
H22: engine, tranny = 475lbs.
are u serious?
All three of this guys posts are BS. This foo is trippin.
YABOY_DONDON
14
Mar 26, 2013 01:15 PM
second edition
Jun 17, 2006 10:14 AM
DIY_Racing
Nov 13, 2004 01:53 PM
