power window conversion on civic
I tried to do a search but couldn't find the answer... but my question is:
Can i use the driver and passenger side harnesses and regulators from a 98 integra and use them on my 97 civic HB? thanks!
In other words... can i just use all this stuff from the teg and put it on my hatch... thanks!
I don't plan on using the floor harness because i plan on just hotwiring some power to the door harnesses. It's been done before and I've been told I could do it that way. I just wanna know if the teg stuff will bolt onto my civic doors.
If they do fit would you mind doing a write-up? I've got a new set of doors that have manual stuff and my current doors are power. I want to know how much of a pita it is to do so I know how much time to set aside.
im not 100% sure but i think it should work for the civic, and manual to power windows arent really too hard to do, we just did a conversion on my friends 93 ej, and it works great, u just have to wire it right, pretty simple though, didnt take us too long, good luck.
thanks but my biggest concern is that those things are off a 98 integra... I hope they fit my 97 EJ. I'll do a write up if it works, thanks!
anyone know for sure if integra/civic regulators are interchangable? thanks!
those regulators are not going to fit your car, you need to get regulators off a 99-00 si, the doors are the same as the ek....as far as the wiring u need all the components, relays and the motors that power the windows, dont forget about the harness that goes to your switches and motor
Hoffy
Aug 12, 2006 06:06 PM
JDM*addiction
Jun 26, 2005 11:00 AM
