What makes engine rev till 5000 ONLY ?
Old Aug 15, 2005 | 03:27 PM
civic_ekek's Avatar
Default What makes engine rev till 5000 ONLY ?
I`m running obd2 to obd1 harness and a stock p28.
I only got a 02 heater sensor code, and the engine wont rev over 5000.
I dont think that code will make the engine rev like that .... could it be somethin else ? Anyone had this prob before ?
Help Pls..
Old Aug 15, 2005 | 03:33 PM
andreysibiris's Avatar
Default Re: What makes engine rev till 5000 ONLY ? (civic_ekek)
did u chipped already your ecu? because if not, that's why.
Old Aug 16, 2005 | 01:52 PM
civic_ekek's Avatar
Default Re: What makes engine rev till 5000 ONLY ? (andreysibiris)
No ecu is stock.
U mean its that code that makes the ecu go in limp mode ?
Old Aug 16, 2005 | 04:09 PM
khabi khabi's Avatar
im assuming its a b series,just had the same problem,read the code again,are you sure its not the vtec pressure switch?your oil could just be low,or the screen near the pressure switch could be clogged or just a bad switch.good luck
Old Aug 17, 2005 | 06:10 PM
Default Re: What makes engine rev till 5000 ONLY ? (khabi khabi)
eyy, i just solved the same friking problem, and my case was behind the manifold, theres a solenoid plug and a sensor plug, i had those in wrong places, the plugs looks the same, but you have to check the wires colors. if the ecu is not recognizing the sensors in the right place, thats why the ecu don't let u passs over 5000 rpm's. its like a protection code for malfunction in sensors. anyways u have to check those wires behind the manifold, and try another ecu chipped.
Old Aug 19, 2005 | 04:02 AM
civic_ekek's Avatar
wot sensors ? can u specify ?
If that was the case though wouldnt the ecu throw the sensor codes ?
i`m only getting an o2 heater code, thats all.
Everthing seems in place. Btw.. mine`s a D series motor.
halfdemonpyro
Aug 2, 2012 03:18 AM
SPOOLINmatt
Mar 17, 2010 05:43 PM
schabilionmk
May 9, 2007 03:36 PM
schabilionmk
May 4, 2007 10:17 AM
Shift_Fast
Mar 11, 2005 06:35 PM
