Inner Tie Rod Replacement
If anyone has any pics or diagrams showing how to remove and replace the inner left tie rod from the rack it would be greatly appreciated. The rod has a lot of play in it and my chiltons has vague directions on how to do this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote"> Might as well remove the whole rack and rebuild it. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Oh, and invest in a Helms. </TD></TR></TABLE>
Haynes is good too.
-Shane
Haynes is good too.
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">
Haynes is good too.
-Shane</TD></TR></TABLE>
Not even close to helmes tho. I have also found quite a bit of incorrect information in haynes.
Haynes is good too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
Not even close to helmes tho. I have also found quite a bit of incorrect information in haynes.</TD></TR></TABLE>
Yea, like the damn ignition firing order that **** is wrong. I went buy that and it took me 2 days to figure that **** out cause its wrong. To hayness
There is a socket that is made for the inner tie-rod, if yours does'nt have notches then just take a air hammer and break it loose with that. After you break it loose you should be able to unscrew it off by hand.
I'll try asking around to see if anyone nearby has a socket to do this, its been a real pain in the *** though
the outer tie rod is stuck to the inner one and Im not sure I would have the time to replace the entire rack. Thanks for the advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Its a BITCH. Might as well remove the whole rack and rebuild it.
No it's not
</TD></TR></TABLE>No it's not
is it necessary? i dont want too unless i have to..
goldegg
Nov 3, 2007 02:35 AM
SoOHiGH
Jul 13, 2005 05:49 PM
david90
Jun 21, 2004 11:10 PM
