suspension problem?
Old Aug 15, 2005 | 12:49 PM
rohec04's Avatar
Default suspension problem?
i have a 92 hatch i lowered the front but only one side got lowered n the other stayed the same what went wrong the driver side doesnt wanna go down
Old Aug 15, 2005 | 12:50 PM
Sijray21's Avatar
Default Re: suspension problem? (rohec04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rohec04 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 hatch i lowered the front but only one side got lowered n the other stayed the same what went wrong the driver side doesnt wanna go down</TD></TR></TABLE>
how did you lower it?...just give us a little more to work with
Old Aug 15, 2005 | 01:01 PM
rohec04's Avatar
i bought some springs for it i just installed them n only one side lowered i also measured the springs to see if they were the same size and they are but i dont kno whats wrong
Old Aug 15, 2005 | 01:12 PM
BlueIntegraBoy's Avatar
Default Re: (rohec04)
Did you put one of the rear springs on the front?
Old Aug 15, 2005 | 01:32 PM
Turbo_y8's Avatar
Default Re: (BlueIntegraBoy)
did you leave the bump stop in on that side? is the spring sitting correctly in the perch on the shock
Old Aug 15, 2005 | 01:41 PM
rohec04's Avatar
i put everything back the correct way
Old Aug 15, 2005 | 02:21 PM
Carpartsguy's Avatar
did u lift it and then put it back down again sometimes it will not seat correctly
Old Aug 15, 2005 | 02:22 PM
JDM-97CX's Avatar
Default Re: (97dxSi motor)
Try bouncing the car from the shock tower. This can help to "settle" the spring.
Old Aug 16, 2005 | 12:06 PM
BoOstedEM1's Avatar
So how did you measure it when it was off or when it was on....try the bouncing method listed above....
Old Aug 16, 2005 | 12:21 PM
Sijray21's Avatar
do the springs have any writing on them?
if so write them on there and tell us the location (ie: front drivers, etc)
possible you have two different spring rates?
how much of a difference is it between sides?
Old Aug 16, 2005 | 02:41 PM
BoOstedEM1's Avatar
That is also true you might have different spring rates...what does the company say about the spring rates for the exact ones you got....
EK_B
Oct 8, 2007 08:02 AM
michjdm
Mar 2, 2007 03:38 PM
hybrid_vtec
Suspension & Brakes
May 31, 2005 08:35 PM
92inprogress
May 19, 2005 08:41 AM
esoterEK..
Oct 3, 2004 02:58 PM
