107 k miles maint. light flashing
turned my car on on the 14th and the light for maintenance required is flashing. What needs to be done at this mileage? (107.5 k) im kinda confused if ne one could post what they had done at this time lemme know? im aware of how to turn the light off but i dont wanna neglect my integra
~thanks for your help
Nothing different at 107.5K. When was the last time you changed your oil?? Did you have your timing belt changed at 90k? Also when was the last time you performed a tuneup (spark plugs, cap & rotor, air filter, etc)
Just as a note, the MRL is just a dummy light and doesn't mean anything is wrong with your car.
No need to panic.
Reiterating what Timmy had said, jus make sure your car is in current standings within the appropriate maintenance requirements according to your milage.
full tune up was done and my radiator was flushed done about 5k miles ago, 1500 miles ago i had full oil change with syntec 1 oil. im think its just a brake check
Blue teg
Nov 9, 2001 11:58 PM
