where to buy high temperature bolts for turbos?
I need to buy bolts for the manifold to turbo and 4 more for the exhaust side on the turbo. (Garrett t3 60 trim) Where is the best place to buy bolts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">I just used grade 8 bolts from a hardware store</TD></TR></TABLE>
yep, that's all I did. I used Hardware store bolts and lockwashers (see pic) on downpipe and manifold. No problem whatsoever.
In my experiences, any loctite won't do anything, the temps just get way too hot for even the high heat loctite. I've found that STUDS are the best thing to use with lockwashers and nuts. Good luck. Paul
yea the loctite will burn away, even the red kind. There is an industrial kind that is really, really high heat resistant, but good luck finding it.
I do also suggesting using nuts also. Even if the bolts thread into the manifold, use longer ones so they come out the top and put a nut on them, this is also where you want the lockwasher if there is enough room. Hell, double nut them if possible.
usually, brand on brand new turbo setups, my experiences have been the bolts will back out. After you tighten them a few times, they will finally stay. That is as long as you used some of the methods mentioned. (lockwasher, nut)
If you still have problems with bolts backing out. Get a safety wire kit. Basically you drill holes through the head of the bolts and put a wire through each bolt so that they cannot back out.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c »</TD></TR><TR><TD CLASS="quote">In my experiences, any loctite won't do anything, the temps just get way too hot for even the high heat loctite. I've found that STUDS are the best thing to use with lockwashers and nuts. Good luck. Paul</TD></TR></TABLE>
yea automotive studs with nuts are the way to go for the DP...i used bolts and they broke off....grade 8 stainless......
but with teh studs ive had no problems....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake »</TD></TR><TR><TD CLASS="quote">
but with teh studs ive had no problems....</TD></TR></TABLE>
So does a hardware store or something similar carry these studs?
carefull when picking stainless steel... its softer that regular steel and the thread my become warped and become a pain in the future under a lot of toque... depending on what you are trying to do.
So I should basically use four stainless steel grade 8 studs on the manifold with four locking washers and and double the nuts on the stud.(
Since the downpipe is four bolt, I should use four stainless steel grade 8 bolts with locking washers.
How does this sound?
or
) Since the downpipe is four bolt, I should use four stainless steel grade 8 bolts with locking washers.
or
I've done quite a few swaps in my garage, and have had nuts/bolts left over from parts that I didn't put back on so I just used those. They work great. For the downpipe I used flywheel wheel bolts. Works good for me.
In my experience anything I got from the hardware store cracked after while...
i just slammed a really long bolt with a nut on it, and put the bolt all the way in and then tightend down the nut, it seemed to work really well
i use studs for my mani to turbo, but i bought a set of lock-tabs from nissan (so the nuts holding the turbo to the manifold dont back off). theyre for a 96 300Z turbo, for the exact same location, the turbo to the manifold studs, and they work great since NOTHING else worked to keep the nuts from backing off. they were like 7 bucks, and well worth it
I got my studs from ATP turbo. I was wondering about material choice for nuts, bolts, washers, and studs, if anyone knows why one is better than the other.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sway892 »</TD></TR><TR><TD CLASS="quote">Here is the setup:
OBX ramhorn manifold
OBX 3" downpipe
Don't bother with the bolts, you won't have it long anyway.
OBX 3" downpipe
