Suspension & Brakes Theory, alignment, spring rates....
KSport/D2 initial setup questions
Old Aug 15, 2005 | 09:21 AM
DSMu4ia's Avatar
Default KSport/D2 initial setup questions
Ok, just got my Ksports in.
Rather than guessing at what they should be, and how to set them up (no instructions rule), I figured I'd ask you guys.
I see three adjustments on my DSM kit (http://www.doitbig.org/dsm/new_suspension/). One being the adjuster on the shock body itself, the second will be the adjustment nuts under the spring, and third being the actual damping adjustment.
What adjustment controls ride height? What adjustment controls pre-load? I heard you should set coilovers up with an inch or so of pre-load?
Any basic thoughts or ideas or links would be greatly appreciated, thanks.
Old Aug 15, 2005 | 11:08 AM
SMZ GSR's Avatar
Default Re: KSport/D2 initial setup questions (DSMu4ia)
When I contacted K-Sport about installing them on my WRX, they said the preload was already set and that you should just adjust height from the bottom piece (unless of course you have some reasong to increase the load)
As far as dampening, test drive the setup and find out what works best for you I think you'll be very happy with them, I know I am
Old Aug 15, 2005 | 12:28 PM
DC4_MADMAN's Avatar
Default Re: KSport/D2 initial setup questions (SMZ GSR)
I'll be putting mine in Friday and I am just gonna follow the setup for the omnis for preload.
Old Aug 15, 2005 | 02:51 PM
SMZ GSR's Avatar
Default Re: KSport/D2 initial setup questions (4door_demon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">I'll be putting mine in Friday and I am just gonna follow the setup for the omnis.</TD></TR></TABLE>
Call Ksport if you have questions. http://www.ksportusa.com
Old Aug 18, 2005 | 03:02 PM
BodyKits NW's Avatar
Since both of you are my customers, hit me up if you have any question. Like I said we've got a lot of experience with the Ksport product and suspension systems.
marecco
Suspension & Brakes
Nov 5, 2007 09:22 AM
hondaej8
Apr 15, 2007 01:28 PM
evolvedAP1
Jul 8, 2006 06:29 PM
cheehee
Suspension & Brakes
11
Jun 14, 2005 01:21 PM
suprafly20
Jan 25, 2002 10:14 AM
