Bent valve?
Old Aug 15, 2005 | 08:49 AM
Ben_si's Avatar
Default Bent valve?
Hit the juice yesterday and a whiteish cloud of smoke came out of my exaust, my car was running on 3 cyl. I had a flashing check engine, took out the plugs, my 3rd cyl. plug was black and had the tip blown off, the 3rd cyl. reads 0 psi on the compresson test, when you put psi in the 3rd cyl. air leaks out of the 1st cyl. Blown valve(s)? blown rings?
Old Aug 15, 2005 | 08:51 AM
Pioneer162's Avatar
Default Re: Bent valve? (Ben_si)
I'm soooo sorry. Sounds like more than a bent valve though. Good luck on the rebuild.
Modified by Pioneer162 at 10:04 AM 8/15/2005
Old Aug 15, 2005 | 08:58 AM
Frozen E's Avatar
H-T White Ops
burned valve
Old Aug 15, 2005 | 09:20 AM
Ben_si's Avatar
Default Re: (IslandSi)
Im gunna rip the head off to nite and check everything out. Im thinking its a valve
Old Aug 15, 2005 | 09:24 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (Ben_si)
so where did you hear the leaks when you did the leakdown test? intake manifold or out the exhaust manifold?
Old Aug 15, 2005 | 01:01 PM
Ben_si's Avatar
Default Re: (BrokeAssPinoy)
When I did the leakdown I did it on the 3rd cyl. and air came out of the 1st cyl. I dont really understand how that happens
Old Aug 15, 2005 | 06:06 PM
BLOODTYPEH's Avatar
The crankshaft is designed so that the pistons in cylinders 1 and 3 move in sync. So when 1&3 are decompressed, pistons 2&4 are compressing. Most likely when you did a leak down you had the pistons decompressed which allows air from on cylinder to enter the camber of the other cylinder housing
Old Aug 15, 2005 | 06:45 PM
B_series_'s Avatar
ouch.
thewrai6th
Jan 20, 2010 05:00 PM
92integraVTECgsr
10
Oct 17, 2009 11:13 PM
JJ's civic
May 29, 2006 08:25 PM
Blaze45
Jan 23, 2003 08:17 AM
hondafrk
Jul 31, 2002 07:36 PM
