running full Synthetic on a turbo car(searched,Nothin)
Old Aug 15, 2005 | 08:21 AM
Brycen's Avatar
Default running full Synthetic on a turbo car(searched,Nothin)
Hey guys just wondering how i would go about changing from regular conventional oil to full synthetic for my accord.Im not really sure how to go about changing it to full synthetic.I have heard you have to gradually change it to synthetic but im just wondering the correct way,thanks in advance.
Old Aug 15, 2005 | 08:45 AM
v4lu3s's Avatar
RTFM
usually what i do is drain the old oil.
then i change the filter.
then i pour the new synthetic oil into the engine.
if that doesnt work i dont know what else coud possibly make it happen.
Old Aug 15, 2005 | 08:48 AM
JadedGamerX's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">usually what i do is drain the old oil.
if that doesnt work i dont know what else coud possibly make it happen.</TD></TR></TABLE>
When people post the correct answer sarcastically, that makes me laugh.
Old Aug 15, 2005 | 08:57 AM
Brycen's Avatar
Default Re: (JadedGamerX)
Yeah he did not read the post correctly evidently,it says how to change it from conventional to sythetic,not how to change the oil i know how to do that,im not a retard..smartass.
Old Aug 15, 2005 | 09:52 AM
v4lu3s's Avatar
RTFM
if im a smart *** you are a dumb ***.
i told you exclty how to change your oil from convetnional to synthetic, or from synthetic to conventional or from castor oil to **** water. its an oil change not rocket science. the only difference is what is in teh bottle you pour in.
maybe i should use stupid *** instead of dumb ***.
Old Aug 15, 2005 | 10:42 AM
Nick H's Avatar
New User
to clarify, there is no process of mixing synthetic with conventional...in fact, don't do that...just switch 'em...
Old Aug 15, 2005 | 11:30 AM
Eddiebx's Avatar
Default Re: (Brycen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brycen &raquo;</TD></TR><TR><TD CLASS="quote">Yeah he did not read the post correctly evidently,it says how to change it from conventional to sythetic,not how to change the oil i know how to do that,im not a retard..smartass.</TD></TR></TABLE>
if you think theres a "process" to change from coventional oil to synthetic, then yes you are a retard
you asked how, and he told you how, deal with it
Old Aug 15, 2005 | 06:41 PM
VtecPMP's Avatar
haha, good stuff
Old Aug 16, 2005 | 07:53 AM
twkdCD595's Avatar
Default Re:
Depending on the mileage of the motor I would thinking about it first before you switch to synthetic engine oil.
Imo.... if the motor is pretty low mileage... and does not consume oil... you could most likely get away with a switch to synthetic at your next oil change.
However if your motor is like most accord motors... you got some pretty heavy mileage on it using regular oils and whatnot... switching to synthetic is probably not the best in this case. The syn. oil is too slick and will get by the old rings... subsequently the engine will most likely start to use oil (more oil if it already does use some) and you will see smoke out the tailpipe.
I was worried about going to a full synthetic personally, so I run the blend stuff in my turbo accord... I started using this stuff just after I turned 80k miles... I am at 89k currently and everything is still good.
Old Aug 16, 2005 | 08:10 AM
maroonaccord2.2's Avatar
Default Re: running full Synthetic on a turbo car(searched,Nothin) (Brycen)
I agree, (my '92 Accord LX has 220K, still runs like new) I'd run a "high mileage oil" of you are pushing over 100K, but there is no "procedure" for changing to full-synthetic......just make the change.
Old Aug 16, 2005 | 10:59 AM
VtecPMP's Avatar
When I first bought my 94 accord that had 135k miles I changed to Mobil 1 and so far the car runs GREAT.
Old Aug 20, 2005 | 01:25 AM
i_kick_turtles's Avatar
Default Re: (VtecPMP)
101K miles, full sythetic, runs just fine.
socallmechris
15
Jan 20, 2008 09:44 AM
Lithel
10
Aug 24, 2007 11:24 AM
NAlover
May 8, 2007 04:37 PM
yujintheman
Honda Civic (2006 - 2015)
Feb 9, 2007 06:26 PM
Francesco
Honda S2000
24
Apr 27, 2006 04:51 AM
