Advantages to "tuning" in 3rd gear instead of 4th on a DYNO
Old Aug 15, 2005 | 08:04 AM
cruzersi99's Avatar
Default Advantages to "tuning" in 3rd gear instead of 4th on a DYNO
I know most people tune in 4th because it's gear ratio is closer to 1.
Old Aug 22, 2005 | 02:34 PM
cruzersi99's Avatar
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (cruzersi00)
Anyone?
Old Aug 23, 2005 | 07:12 AM
Black R's Avatar
25 Year Member
the advantage is that when you're paying hourly for dyno time, you can take more pulls since 3rd pulls faster through the rpm range.
3rd gear always give me less peak #'s... so you know it has a little more in it when you go to 4th.
for the final run, i do 4th - just to make sure she's nice and smooth - 4th has better resolution and detail (imho). more load, y'know.....
Old Aug 23, 2005 | 07:28 AM
RYANR1's Avatar
Does it have anything to do with 4th being a 1:1 direct drive ratio on most 5spds?
cruzersi99's Avatar
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (Black R)
Kenny, I was always under the impression that third would result in higher readings.
Old Aug 23, 2005 | 07:33 AM
RYANR1's Avatar
I think 3rd gear would give more hp because of the gear reduction.
Old Aug 23, 2005 | 01:24 PM
Black R's Avatar
25 Year Member
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (RYANR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYANR1 &raquo;</TD></TR><TR><TD CLASS="quote">I think 3rd gear would give more hp because of the gear reduction.</TD></TR></TABLE>
.....well on the several different dynojet's I've used, 3rd gear always reads lower.
It doesn't matter, since it's only a couple hp either way.
The point it to get consistent readings.
Old Aug 23, 2005 | 04:38 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYANR1 &raquo;</TD></TR><TR><TD CLASS="quote">Does it have anything to do with 4th being a 1:1 direct drive ratio on most 5spds?</TD></TR></TABLE>
4th isn't 1:1 on many FWD transmissions, if any. (I'm sure there's at least a few out there) It is on a lot of RWD, but FWD skips around it.
Remember, horsepower is the same for each gear. It might be a little different due to changing torque readings from the loss in the transmission, but mathematically it's the same.
Also, don't forget the gear ratio correction the ecu performs for each gear...
Old Aug 23, 2005 | 06:59 PM
cruzersi99's Avatar
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (drdisco69)
So why 4th instead of 3rd?
Old Aug 23, 2005 | 07:52 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
The point it to get consistent readings. </TD></TR></TABLE>
Same here.
All my posted plots are 3rd now that I think of it.. Doh
Old Aug 23, 2005 | 08:04 PM
MAX_CFM's Avatar
on a Dyno Jet 4th gear allways makes more peak .....
Old Aug 23, 2005 | 11:09 PM
Mike K's Avatar
Default Re: (MAX_CFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">on a Dyno Jet 4th gear allways makes more peak .....
unless you have an ATS 3-4-5 gearset. then you'd want to use 5th.. since it redlines at about 110mph anyway.
Old Aug 24, 2005 | 06:00 AM
Black R's Avatar
25 Year Member
Default Re: (Mike K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">
unless you have an ATS 3-4-5 gearset. then you'd want to use 5th.. since it redlines at about 110mph anyway.</TD></TR></TABLE>
Actually, that is a good tip!
-t3h r0ck3r, who has yet to install these bad boy pieces sitting in his trunk.....
Old Aug 24, 2005 | 06:29 AM
b19coupe's Avatar
Almost always. On my last trip to the dyno we made a fourth gear pull after tuning and the car made less.
Old Aug 24, 2005 | 08:41 AM
MAX_CFM's Avatar
Default Re: (b19coupe)
Sorry Let me rephrase that .. With High Horsepower setups.. and tuned in each gear..
Old Aug 24, 2005 | 08:54 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruzersi00 &raquo;</TD></TR><TR><TD CLASS="quote">I know most people tune in 4th because it's gear ratio is closer to 1.</TD></TR></TABLE>
sometimes we spin in 3rd and strapping harder doesn't always help (plus eats away at power), so we use 4th ... it puts alot more load on the engine
also remember Larry W said that it may also help settle the exhaust timing events in the higher gears.
Greg
Old Aug 24, 2005 | 09:05 AM
MadnessRacing's Avatar
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (CHEETAH)
sometimes it depends on the horse power but its more accurate to tune it in whatever gear you are when you crossed the 1/4 mile..
Old Aug 24, 2005 | 09:07 AM
Rocket's Avatar
The rate at which at which the mass of the engine is absorbing energy is higher in 3rd gear. On engine dynos there are inertia factors to compensate for this.
Old Aug 24, 2005 | 09:08 AM
Supernatural's Avatar
Default Re: Advantages to "tuning" in 3rd gear instead of 4th on a DYNO (Rocket)
awww boo no more switching wheels for more power
Rocket
46
Sep 30, 2010 10:42 PM
VTIargentina
Oct 23, 2009 10:43 AM
daluv
Engine Management and Tuning
Aug 27, 2008 05:16 PM
EJ1 wilcox
Apr 30, 2007 12:22 PM
TypeR0149
Mar 19, 2002 02:59 PM
