Foglight Lighting Problem
Old Aug 15, 2005 | 02:50 AM
BlueIntegraBoy's Avatar
Default Foglight Lighting Problem
Ok, here's the story: I was at the drags last night. During midway on the track my charging light comes on. I was returning to the pit area and noticed my car vibrating a little bit. I thought I busted a motor mount. Anyways, I popped my hood to find out that my crankshaft pulley is crooked and my alternator belt missing. I find out that the crankshaft pulley bolt came loose, the pulley turned sideways, and ripped my alternator belt off. I was towing the car back to my friend's shop and he was in my car and I was in the tow car. I noticed my foglights were on during the tow, but as soon as we reached his shop the foglights turned off. I haven't been able to get them back on.
I hard wired the foglights to my battery and the foglights turn on. I checked my fuse and it turned out to be good. My relay is clicking as well. My foglight switch illuminates too and the green light turns on when pressed. I haven't been able to search for the problem since I was busy today.
I posted to view other members' opinions on where to locate the problem before I search tomorrow. I might be thinking it's the wire connecting the interior harness to the engine bay harness. Guidance is appreciated.
Modified by BlueIntegraBoy at 2:15 AM 8/15/2005
Old Aug 15, 2005 | 03:10 AM
94_HATCH's Avatar
Default Re: Foglight Lighting Problem (BlueIntegraBoy)
maybe the pulley knocked some of the fog wiring loose?
Old Aug 15, 2005 | 03:14 AM
Default Re: Foglight Lighting Problem (94_HATCH)
I ran the single wire along the driverside headlight wiring harness. From visual inspection, the wire still looks intact.
Old Aug 15, 2005 | 04:57 AM
JDMlyfestyle's Avatar
Maybe not enough juice to click over on the relay? i doubt they are very bright when u connect them to the battery are they?
Old Aug 15, 2005 | 11:32 AM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Maybe not enough juice to click over on the relay? i doubt they are very bright when u connect them to the battery are they?</TD></TR></TABLE>
They were bright. I replaced my alternator belt already and they still don't turn on.
Old Aug 15, 2005 | 11:35 AM
replace the relay
Old Aug 15, 2005 | 11:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">replace the relay </TD></TR></TABLE>
Does it have to be a Honda relay or can I just pick it up from a parts store? Is there a part number for the relay as well?
Old Aug 15, 2005 | 12:14 PM
i got mine at a parts store
Old Aug 15, 2005 | 12:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">i got mine at a parts store</TD></TR></TABLE>
Alright, I'll remove it and see if the parts store has a similar relay. Thanks
Old Aug 16, 2005 | 08:22 PM
Alright, I ordered a new OEM relay from the link below since none of the stores carry the relay in the state.
http://replacement.autopartswa...ory=P
I hope it fixes the problem.
Koko4
Apr 27, 2015 09:32 PM
95DC2GS-R
Aug 4, 2010 07:57 PM
MOVE OVER
Feb 26, 2008 06:15 AM
turbotime
13
Apr 17, 2006 12:19 PM
teler86
Feb 24, 2005 09:00 AM
