plans for all mota setup
i was def. going boost but decided to change it up for a NA setup cause i wanna do somethin a lil different. here's what my setup will be
obd0 b16 block
oversized ctr pistons
eagle rods
b16 crank
gsr head
itr cams
skunk2 im
comptech header
J's racing intake
also i wanna do a clean wire tuck and some minor things. like oil filter relocation and shave the engine bay. i'm lookin to get around 200hp maybe with this setup, if i need to change a few things let me know.
obd0 b16 block
eagle rods
b16 crank
gsr head
itr cams
skunk2 im
comptech header
J's racing intake
i doubt you can hit 200whp. My suggestion would be to change the block to a gsr or ls block.
gl with the all motor setup though.
let us know how it turns out. or keep us updated on this.
you should go with more higher compression forged pistons ... afterall the CTR motor stock is 185hp at flywheel ... all you're doing is recreating a CTR motor with a GSR head and eagle rods.
do some more research in order to reach your 200hp goal. Things like sleeving the block and going bigger bore or using a b17a crank, etc will help achieve your goal.
I have an 86mm bore b16a block sitting on a checl for a year that I need to get to, I'm sure if I wrapped it up it'll come close to 200whp with a stock head.
Greg
Greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">I have an 86mm bore b16a block sitting on a checl for a year that I need to get to, I'm sure if I wrapped it up it'll come close to 200whp with a stock head.
Greg</TD></TR></TABLE>
ha, ya. more like 220hp
sw96
Jan 17, 2010 02:48 PM
JerseySiPOS
Apr 8, 2004 06:16 PM
