So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it...
Old Aug 14, 2005 | 09:08 PM
SlamminS85's Avatar
Default So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it...
So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it... thoughts? Tips?
should i do this, shoudl i not do this? ? ?
Old Aug 14, 2005 | 09:23 PM
usdm97DC4's Avatar
Default Re: So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it... (SlamminS85)
Do it! Im doing mine as we speak. Its fun!
PS. THE PEDALS ARE A BITCCCCCCCCCCCH!
Old Aug 14, 2005 | 09:25 PM
stewmaster-k's Avatar
Default Re: So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it... (usdm97DC4)
my friend is having a proffesional do it when he does his motor swap and everything for only $700, but good luck anyways
Old Aug 14, 2005 | 09:26 PM
Turbo Squid's Avatar
i say do it.. its easy n ur'll learn alot of stuff about ur car. I did mine last week n my friend is doin his rite now.
Old Aug 14, 2005 | 09:33 PM
SlamminS85's Avatar
Default Re: So im undertaking an Auto/Manual swap in my 1993 LS with 86k on it... (bLaCK_GsR)
yeah, dam~(trying to keep it clean), I didn’t know that there were so many people doing this... where to I find pedals and shifter assemblies?
I am having a professional do it as well, but I’m going to help, (i.e. be a tool gopher with a stupid look on his face)
Also beyond Tranny, Clutch, ECU, Flywheel and pedal/shifter, what else am I forgetting
Old Aug 14, 2005 | 09:39 PM
You need a master cylinder, clutch hose, linkage n hasport mount for the tranny. Cuz auto n 5sp have different mount. Thas all i can think of rite now. But good luck.
Old Aug 14, 2005 | 09:43 PM
SlamminS85's Avatar
Its a cable tranny that should bolt directly to my block and have the same mounts as well i think anyway
could i change it from a cable to a hydro?
should i if that is possible?
Old Aug 14, 2005 | 09:44 PM
o ok nm.. u dont need all that then. i was think about hyro tranny.
Old Aug 14, 2005 | 09:51 PM
SlamminS85's Avatar
I may be a noob... but i knew that. I figured it would be best if i nabbed a tranny off of the same year and model engine as mine
anyway, where do i find the pedal and shifter
Old Aug 15, 2005 | 01:53 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">I may be a noob... but i knew that. I figured it would be best if i nabbed a tranny off of the same year and model engine as mine
anyway, where do i find the pedal and shifter</TD></TR></TABLE>
Go to a local salvage yard. They should be very cheap there. Pick up all the parts there. Keep in mind that you may need a 5-speed starter. Doing a swap on the 3rd gens, you do.
Here's a quick list off the top of my head for a 5-speed swap for a 3rd gen:
Tranny
Clutch
Flywheel
ECU (optional)
5-speed starter
Upper tranny mount (either fabricated, rewelded, or purchased)
Linkages w/shift lever
Hard lines
Master/slave cylinder
Misc bolts/screws/nuts
Center console (optional)
Cluster (optional)
Intermediary shaft (also called half shaft)
Clutch pedal assembly
Brake pedal assembly (optional)
I think that's it.
All-Integra20
Oct 11, 2012 05:25 PM
stock96accordlx
Dec 1, 2007 08:14 PM
code47mastermind
Nov 10, 2005 05:28 PM
crazyd
Feb 10, 2005 08:46 AM
