P72 ECU with Skunk 2 manifold
Does anyone have any experience in running the STOCK GSR ecu wit a skunk 2 manifold?. Im running the stock P72 wit Vafc on mt GSR wit Skunk2 IM and Stage 2 cams and just wondering if my car is running right cause the VAFC was dyno tuned but it was a year ago when i was only running I/H/E so im assuming that with my new set up now that my car may not be running at optimum. Is this true. Im working on getting my hondata right now. Could my stock 240 injectors be an issue also?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">You can disable the IABs with a chip, otherwise it will have a check engine light on.</TD></TR></TABLE>
<U>FALSE</U>
There will be no check engine light.
<U>FALSE</U>
IAB wont trip any CEL. Your stock injectors r fine. just wait for hondata and tune the car
i am running obd1 p72in my 92 hatch b18c1 skunk2 mani. dc 4-1 header greddy exhaust aem cold air g-sport 70mm throttle body. It ran a 13.8 quarter. It runs great gas mileage is good. but i had it dynoed and under wide open throttle it got rich after vtec kicked in around 11.7 at 8000 rpm. It could stand to be alittle leaner but i would think if i added some good cams that breathed better on the top end it would even out and have a flat af ratio across the board.But it is only rich when you kick in vtec so who cares about gas mileage then i want power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC »</TD></TR><TR><TD CLASS="quote">me thinks the settings for the i/h/e might be closer to what you want.</TD></TR></TABLE>
why do u think that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK99VTECR »</TD></TR><TR><TD CLASS="quote">
why do u think that?</TD></TR></TABLE>
I'm thinking that your vafc was tuned to give you more fuel, which you will need for the cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC »</TD></TR><TR><TD CLASS="quote">I'm thinking that your vafc was tuned to give you more fuel, which you will need for the cams.</TD></TR></TABLE>
well as of the moment there is no telling if the fuel is in the right places in the right amount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR00SI »</TD></TR><TR><TD CLASS="quote">remember the gsr computer thinks there is a secondary butterfly in the manifold. and there isnt in the skunk 2. this will hurt you./</TD></TR></TABLE>
hondata will fix this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne99GSR »</TD></TR><TR><TD CLASS="quote">Im running P72 facotry GSR ECU with skunk2 IM, I got knock sensor CEL code</TD></TR></TABLE>
well my check engine light isnt coming on so i dont know how its running
This has nothing to do with the fact that your running a stock p72 on a gsr motor with a skunk2 manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">My advice:
Sell the vafc.
Buy a chipped obd1 ecu (uberdata, crome, hondata ready).
Sell the vafc.
</TD></TR></TABLE>................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">................</TD></TR></TABLE>
im getting hondata in due time
hondata will fix this?</TD></TR></TABLE>
yes hondata can shut off those butterflies.
I deal too much with OBD2 cars where the wrong attitude will net you a check engine light...
