VTEC Solenoid gasket issue
Old Aug 14, 2005 | 08:39 PM
rjay8604's Avatar
Default VTEC Solenoid gasket issue
Well my fresh built motor has been running great besides an oil leak. Well i finally decided to stop leaking oil and try to seal it up. Took off my VTEC solenoid (was the leak) and i found my fresh OEM spool valve filter to be split in several places. Here's a pic.
You guys ever had this i am worried its just gonna happen again when i buy a new filter/gasket.
THanks for any input.
Old Aug 14, 2005 | 09:04 PM
Tad's Avatar
Tad
looks like the metal is cracked too, in the bottom right of that image ???
Old Aug 14, 2005 | 10:36 PM
b19coupe's Avatar
Default Re: VTEC Solenoid gasket issue (rjay8604)
Common problem. It's rubber. Heats up, cools down, ages, cracks. New gasket and you won't have a problem.
Old Aug 15, 2005 | 12:03 AM
rjay8604's Avatar
Default Re: VTEC Solenoid gasket issue (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Common problem. It's rubber. Heats up, cools down, ages, cracks. New gasket and you won't have a problem.</TD></TR></TABLE>
Well thats the thing though. This gasket is brand new, i replaced it when i did the buildup. But yeah its not a big deal, i was thinking maybe someone else had a problem like this, maybe the gasket gets pinched between the mating surfaces. Maybe i should oil it before it put it in.
EDIT: ME = OWNED https://honda-tech.com/zerothread?id=1149641
The early JDM b16's had a ever so slightly different vtec solenoid. The gasket looks identical but the early one is thinner. The OBD-0 b16's need the gasket for a 91 NSX, the other USDM solenoid gaskets will not work. you learn something everyday.
Modified by rjay8604 at 3:31 AM 8/15/2005
Old Aug 15, 2005 | 05:52 AM
b19coupe's Avatar
LOL
Old Aug 15, 2005 | 06:28 PM
KingHornet's Avatar
Same thing happened to me. I bought a new solenoid gasket and after a couple of months, oil started leaking out again from that part. I havent pulled out the gasket yet but I think its broken (again).
My friend suggested that I put silicone to seal it better. I might just try that the next time I replace it with another new one. No rush and no biggie though.
Old Aug 16, 2005 | 11:50 PM
rjay8604's Avatar
Default Re: VTEC Solenoid gasket issue (ChampWht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChampWht &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me. I bought a new solenoid gasket and after a couple of months, oil started leaking out again from that part. I havent pulled out the gasket yet but I think its broken (again).
If you have the older VTEC solenoid, get the 91 NSX correct gasket, you won't need any sealant with the correct gasket. I went to take mine off because i figured i'd put some sealant on it, then i realized the gasket was split, so just make sure to get the right gasket.
Old Aug 17, 2005 | 05:17 AM
gabspeed's Avatar
just get a new gasket and put honda bond around it you won't have any problems
airikkCRX
Jan 25, 2024 03:11 PM
supertace91
Oct 26, 2013 12:56 AM
motegicivic
20
Sep 21, 2011 04:57 PM
danielblushtein
Mar 11, 2009 03:34 AM
sirrjibbalott
Apr 12, 2006 07:38 PM
