RC 650cc inj. saturated battery offset for AEM..?
Old Aug 14, 2005 | 08:27 PM
mchuang's Avatar
Default RC 650cc inj. saturated battery offset for AEM..?
I just ordered some new injectors for my car 650cc saturated. I was loading cal map and I went to set up injectors and there was no 650cc saturated. I only saw 550cc and 720cc so what do I select? Anyone
Old Aug 15, 2005 | 03:23 PM
B18 CYA's Avatar
good luck, ur gonna have to send your injectors to aem
Old Aug 15, 2005 | 03:34 PM
alpha's Avatar
Default Re: RC 650cc inj. saturated battery offset for AEM..? (mchuang)
Contact AEM first. Then you will most likely have to send the injectors to them. That's unless someone is willing to share with you Good luck.
Old Aug 15, 2005 | 04:13 PM
mchuang's Avatar
Is there another alternative because there are plenty of injectors not in the list that other people use?
Old Aug 15, 2005 | 04:20 PM
alpha's Avatar
Battery Volts 6 - 16
2550 | 2370 | 1920 | 1500 | 1220 | 1000 | 850 | 720 | 590 | 480 | 380
I have not tested these values but they seemed to work for another AEM EMS user's S2000.
Old Aug 15, 2005 | 05:37 PM
mchuang's Avatar
what would happen if i selected another injector....different brand same size..
Old Aug 16, 2005 | 11:37 AM
timg's Avatar
Check for my S2000 map under the user cal forum on http://www.aempower.com I used an average of 550 and 750cc saturated injector offsets to get mine.
Tim
Old Aug 16, 2005 | 12:15 PM
11psiTurboSI's Avatar
Default Re: (timg)
I notice that to when I downloaded the updated wizard file, so I went with RC750cc saturated injectors
slowwhitehatch
Engine Management and Tuning
Mar 23, 2009 04:29 PM
slowwhitehatch
Mar 23, 2009 04:28 PM
vaporboy12
Jul 24, 2006 03:09 PM
B18 CYA
Aug 16, 2005 01:10 PM
wtc7676
Jul 4, 2004 01:36 PM
