MY CRX is running shitty after a motor swap.
Old Aug 14, 2005 | 07:15 PM
DaCRXboi's Avatar
Default MY CRX is running shitty after a motor swap.
Hi, I did a motor swap into my 89 crx. I put an 94 B18B1 Ls motor. I connect all the parts together and it run, but it is running too RICH!. Cuz im useing my old D16a ecu. I want to do an obd0 to obd1 converison, but i don't know what part i need to get.Can yall help me? I suppose to get an:
-*Obd1 Integra Distributor
-*P75 ECU
-*Obd0-obd1 converison harness
-*do i need to which to 94(obd1)integra fuel injector or can i use 90-93integra(obd0)?? cuz right now im useing my d16(obdo) fuel injector.
any other parts do i need to get???thx
Modified by DaCRXboi at 9:04 PM 8/15/2005
Old Aug 14, 2005 | 07:29 PM
CRX_Control's Avatar
Default Re: MY CRX is running shitty after a motor swap. (DaCRXboi)
you can use obd0 injectors as long as you keep your resistor box .
Old Aug 20, 2005 | 11:04 PM
DaCRXboi's Avatar
Default Re: MY CRX is running shitty after a motor swap. (CRX_Control)
oic...........thx
Old Aug 21, 2005 | 01:40 AM
Bunger's Avatar
4 wire O2... but besides that, as long as you're running the B18B FPR, then you should be good to go!
Old Aug 21, 2005 | 06:58 AM
b18_crx's Avatar
Default Re: MY CRX is running shitty after a motor swap. (Bunger)
yeah pm6 ecu will run that motor but if u want to stay obd-0 use 90-91 integra Ls Ecu (PR4)............. the only reason you should convert to obd-1 (imo) is if ur going with like hondata for boost and tuning or a chipped p28.....just my .02 cents
Old Aug 21, 2005 | 05:27 PM
DaCRXboi's Avatar
Default Re: MY CRX is running shitty after a motor swap. (b18_crx)
at first i was to just about to go 91 Pr4 ecu, but i heard convering to obd1 help save more gas, right??
JohnMumie
Jan 8, 2013 10:54 AM
vtecjunkie228
Oct 9, 2010 05:21 PM
munchies91crx
34
Sep 20, 2009 05:59 AM
civicxxman
11
Mar 2, 2008 05:40 AM
boosh
Sep 25, 2003 01:14 AM
