Strange noise after clutch/flywheel change
Old Aug 14, 2005 | 01:49 PM
Frndsrbullets's Avatar
Default Strange noise after clutch/flywheel change
I recently changed my clutch and flywheel out for an exedy full face with heavyduty pressure plate and an exedy 9.1 pund flywheel. Now when the car is high up in revs it will make a resonant metallic sound. It only makes the noise under a load, because I jacked the car up and revved it and heard nothing. If you have any input that might be helpful I would greatly appreciate it. Thanks
Old Aug 14, 2005 | 05:16 PM
rustyhatch's Avatar
Default Re: Strange noise after clutch/flywheel change (Frndsrbullets)
did you do the work yourself? did you have the flywheel checked to make sure that it is perfectly flat?
Old Aug 14, 2005 | 05:57 PM
Default Re: Strange noise after clutch/flywheel change (rustyhatch)
I did do the work my self, but no I didnt have it checked. When i ran the car on stands it made no noises at all. As soon as I put it back down and drove it it did the same thing.
Old Aug 14, 2005 | 05:58 PM
PaChiLa Leader's Avatar
resurface the flywheel maybe?
Old Aug 14, 2005 | 07:37 PM
Default Re: Strange noise after clutch/flywheel change (PaChiLa Leader)
It is brand new
Old Aug 15, 2005 | 07:16 AM
ttt
Old Aug 17, 2005 | 02:39 PM
up
dannysolis92005
Jul 21, 2009 09:43 AM
akira712
May 7, 2006 12:42 PM
CNSK
Dec 13, 2004 01:13 PM
AlxSiR7
Sep 21, 2004 02:32 PM
Asahi
Aug 1, 2002 06:47 PM
