1992 accord --difficult starts and motor mount replacements
Old Aug 14, 2005 | 10:23 AM
tomkeklak's Avatar
Default 1992 accord --difficult starts and motor mount replacements
on very hot sunny days the accord(1992) is very difficult to start--at present have a new set of plugs, wires, point, fuel filter--this happen every summer the last five or six years--several times a summer--in all cases except toda--letting the car rest several hours resulted in start ups.
also there is a rough hestitation at initial acceleration, or when at complete stop and then acceleration-mechanic says at 154,000 miles the car may need replacement of motor mounts--he looked at in shop acceleration showed some engine shimmy.
is there any other reasons for the hesitation--even after the tune up
thanks,
Old Aug 14, 2005 | 11:09 AM
deserthonda's Avatar
Default Re: 1992 accord --difficult starts and motor mount replacements (tomkeklak)
mmm interesting u got a new set of points as well an a 92 accord??? i hope u did not get charged for that ,, maybe points are worn already ........ok i am being a smart *** last honda that used point s was almost 20 years ago .........ok to serious business
you could have a bad main relay the soldering crack and in hot humid weather especially it wont start the car....try a quick test get a can of carb cleaner, remove tube that goes to throttle body when car does not start spray carb cleaner in throttle body if car starts i would remove the relay and chk for cracked solderings ,,,the main relay is located under left side of dash left side of steering column if u have cruise control u need to remove the cruise control unit box 2 10mm bolts ,,after that if u look up under dash relay has 7 wires going to it it is brownish/rusty color ,,
i dont think broken motor mounts will cause a rough hesitation or bogging ?? at initial accell ,, engine shimmy yes u might have a different issue with hesitation
Old Aug 14, 2005 | 12:37 PM
B18CUL8R's Avatar
change your main relay
Old Aug 14, 2005 | 01:14 PM
tomkeklak's Avatar
Default Re: 1992 accord --difficult starts and motor mount replacements (deserthonda)
sorry for stating that it was points--the items were rotor and caps-thanks for your response
Old Aug 14, 2005 | 01:38 PM
NAiL05's Avatar
If you wanna save money. Get you a solder iron and some solder and resolder the cracks in the main relay. I think a new main relay from Honda cost around 50?
DowneyB
Jan 3, 2019 01:46 AM
bravestarr82
Dec 16, 2013 10:58 PM
Cabral530
Sep 3, 2012 04:51 AM
MattTwinTurbo
Aug 7, 2002 10:05 PM
